Re: Carb vs EFI... a decision I am contemplating
[Re: DaveRS23]
#2389799
10/19/17 01:10 PM
10/19/17 01:10 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Carbs if right are generally faster then aftermarket TBI just a thought. Yep, and EASY to tune if you don't mind installing a wide-band and making a few tweaks............ Thumper can get a carb 'happening' for less than half the EFI money. When EFI gets close to carb prices and uses a dry manifold, I might just consider it. Don't know what the EFI systems run $$ wise and don't care either way but do what you need to do AFTER you try the new and improved main body.........
[Re: Jeepmon]
#2389864
10/19/17 03:38 PM
10/19/17 03:38 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Ok - follow your gut instinct ... but check out this dyno run of the pump gas Hemi that I had MM finish up for me back in the spring: https://youtu.be/95gZTspdzsg It starts right up, idles real nice and learned it's own tune over several dyno pulls. That's a dual throttle body FAST EZ-EFI 1.0 up on top. 888 HP @ 6300 RPM ... I just need to find the other 12 ponies so I can say I have a 900 HP street engine!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: Jeepmon]
#2389974
10/19/17 07:24 PM
10/19/17 07:24 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Carb has worked fine when I'm there Just take that POS off and send it to me. Ill send you a Division winning one to replace it, was good enough to be in a ton of finals racing .90 should be good enough for you. Oh yeah loose the lexan scoop or start cleaning your air bleeds AT EVERY RACE!!! We live and race at places that are filled with dirt, it don't take much to clog a .029" hole...My guess is you already had someone try to make it better and they either lost the intermediate circuit or put a HUGE bleed in there. That aint the way to make it happy on the stop... Oh yeah don't waste the time energy and money to go EFI, unless you just have to be different. If it was more consistent every bracket and class hitter in the country would run it. Also inline stops=crap for consistency especially for cars on the stop for a fair amount of time. Once again if it was the hot ticket Bogacki and every other racer in S/G, S/C and S/ST would have already done it. But what do I know...
[Re: Triple Threat]
#2389975
10/19/17 07:26 PM
10/19/17 07:26 PM
Al_Alguire
Las Vegas
I'd bolt a different Carb on it long before I attempted that switch. We have 1 person in D6 with Holley EFI on their 145mph SST car and he has told me it is a struggle to make it work. I have offered one up more than once....And if he was pout winning every round he would not be alone
[Re: Al_Alguire]
#2389984
10/19/17 07:49 PM
10/19/17 07:49 PM
Thumperdart
State of confusion
Carb has worked fine when I'm there Just take that POS off and send it to me. Ill send you a Division winning one to replace it, was good enough to be in a ton of finals racing .90 should be good enough for you. Oh yeah loose the lexan scoop or start cleaning your air bleeds AT EVERY RACE!!! We live and race at places that are filled with dirt, it don't take much to clog a .029" hole...My guess is you already had someone try to make it better and they either lost the intermediate circuit or put a HUGE bleed in there. That aint the way to make it happy on the stop... Oh yeah don't waste the time energy and money to go EFI, unless you just have to be different. If it was more consistent every bracket and class hitter in the country would run it. Also inline stops=crap for consistency especially for cars on the stop for a fair amount of time. Once again if it was the hot ticket Bogacki and every other racer in S/G, S/C and S/ST would have already done it. But what do I know... Ya, do this and enjoy the blubbery ass 3-circuit crap that MOST don't need or even understand............Gimme a break..........Forest has a 2-circuit and runs a stop and did I mention he just won a wally..........
[Re: Jeepmon]
#2389991
10/19/17 08:06 PM
10/19/17 08:06 PM
Al_Alguire
Las Vegas
Dom and INLINE stop and a baseplate stop are TWO completely different things. Re read what I wrote... Oh yeah I have a pile of Wallys too, but how was that possible with three circuit junk, that Bogacki guy does ok with his too since we are gimmmeing us a break
[Re: Triple Threat]
#2390637
10/21/17 01:41 AM
10/21/17 01:41 AM
Al_Alguire
Las Vegas
Lexan scoops win races in my neck of the woods in your neck of the woods you don't race at dusty facilities either. Unless you count Boise as High Desert dust..lol...
