Carb vs EFI... a decision I am contemplating
#2389418
10/18/17 05:35 PM
10/18/17 05:35 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I have a custom built Braswell Carb that I have never been happy with... Seems that it is either too rich... too lean... bad idle quality or will bog out when going on the transbrake at the line... (lost a couple races because of it)...
I've sent it off to so-called "experts" and fiddled with it myself and quite frankly, getting quite frustrated with it..
In talking with Rich (EFI FASTMAN)... we've discussed converting to the Holley system and of course, Rich will bend over backwards to make sure it is tuned to optimum performance..
I mostly bracket race in S/ST 10.90 @ 149-ish... Have done a few all out races at 155-ish MPH... The car has a Dedenbear disc style throttle stop and I'm debating whether to throw in the towel and convert to EFI or stay with the carb...
I know I will have to replace the throttle stop with a linkage style, will need a new fuel pump and of course, the install of the Holley system... Approx cost will be slightly over $2400.00, but can sell the Brasswell, Dedenbear and BG400 pump to help recover some of the cost..
Would you do it... or would you continue to try and make the carb work? and why?
Re: Carb vs EFI... a decision I am contemplating
[Re: Jerry]
#2389431
10/18/17 06:05 PM
10/18/17 06:05 PM
Jeepmon
Sunnyvale, CA
efi all the way. take a look our crank trigger mounts for 36-1 trigger wheels and the cps bushings for running distributorless ignition. there is no comparison between EFI and a carb. consistency in all conditions and auto adjustment for optimum performance from the EFI. I've heard from multiple sources that no matter how much money they throw at an EFI system, they can not get consistency when using a throttle stop...
[Re: Jeepmon]
#2389435
10/18/17 06:10 PM
10/18/17 06:10 PM
Posts: 916 SE Washington
Forest
SE Washington
efi all the way. take a look our crank trigger mounts for 36-1 trigger wheels and the cps bushings for running distributorless ignition. there is no comparison between EFI and a carb. consistency in all conditions and auto adjustment for optimum performance from the EFI. I've heard from multiple sources that no matter how much money they throw at an EFI system, they can not get consistency when using a throttle stop... That would be my concern...getting the throttle stop to work correctly. Saying you do convert to EFI, what about alcohol too?
[Re: Paul_Fancsali]
#2389446
10/18/17 06:35 PM
10/18/17 06:35 PM
Thumperdart
State of confusion
Carbs if right are generally faster then aftermarket TBI just a thought. Yep, and EASY to tune if you don't mind installing a wide-band and making a few tweaks............
[Re: Jeepmon]
#2389453
10/18/17 07:00 PM
10/18/17 07:00 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I just went with the Holley Dominator EFI. While there was a cost associated with it, it's amazing. Being able to control exactly what, and when the system does things, is awesome.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: Jeepmon]
#2389506
10/18/17 09:04 PM
10/18/17 09:04 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Send it to Thumpercarb, he cleaned the idle up on my Prosystems 950HP, it just explodes off the line now.
Before he worked on it nothing I did would help, now it's just a little tweak on the idle screws...And I'm at 7000 to 8000 foot DA
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Jeepmon]
#2389565
10/18/17 10:33 PM
10/18/17 10:33 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I think giving Thumper a shot at fixing your carb is worth a try. You could still always sell the carb if things don't work out. If it does work, you are ahead of the game. Someone on here posted about his EFI system going down, losing Comm. I don't remember if he even posted about getting it fixed. Just something else to think about with EFI.
[image][/image]
[Re: Jeepmon]
#2389578
10/18/17 10:53 PM
10/18/17 10:53 PM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
I have been very happy with my EFI stuff, I haven't ever run this motor with a carb so I don't know if it is faster or not. I do know I have zero plans to go back to a carb. I can't speak for throttle stop stuff but my car has been incredibly consistent with the fuel injection.
68 Barracuda Formula S 340
[Re: Thumperdart]
#2389585
10/18/17 11:05 PM
10/18/17 11:05 PM
Posts: 12,243 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Carbs if right are generally faster then aftermarket TBI just a thought. Yep, and EASY to tune if you don't mind installing a wide-band and making a few tweaks............ Thumper can get a carb 'happening' for less than half the EFI money. When EFI gets close to carb prices and uses a dry manifold, I might just consider it.
Master, again and still
[Re: Jeepmon]
#2389701
10/19/17 04:38 AM
10/19/17 04:38 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
The EFIstore.com Brian Macey is the best there is
[Re: Jeepmon]
#2389737
10/19/17 10:56 AM
10/19/17 10:56 AM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Three years ago, I was in the same spot as you are. I have lots of carb stuff but just decided to start moving to EFI. I know I won't make any extra HP but I hope to not give up too much either. I'm 90% street and 10% strip so the advantages of cold startup, hot restart, no distributor ignition and closed-loop learning are just too compelling for me to stick with carbs. Tuning everything with a handheld (FAST EZ style) or with a laptop computer is just way easier and offers flexibility as you change things. Changing jets, pump shot cams and then messing with timing curves with springs, weights and welded up slots is just too Oldschool for 2017. My carb stuff idles a bit rich and I'm getting under 7 miles to the gallon on my 500" Wedge with a decent sized solid cam and Mighty Demon 850 annular boosters carb (no choke). I guess that the 4.88's in the Dana don't help much on the highway! My plugs are heat range cold and I'm running a MSD Digital 6+ for ignition that burns any extra carbon off the plugs and keeps them from looking rich. My next step should be more carb tuning to lean it out but I guess I'm getting lazy. Since it's finally running pretty good, I figure that must be the sign that it's time to start all over again with EFI I started out with FAST EZ EFI 1.0 and now I'm moving to FAST XFI-XIM stuff just because I was able to pick it up cheap as another guy moved to Holley EFI. I have three kids in college so the Mopar Fun Money Fund is pretty lean. The newer Holley stuff seems to be the way to go. And FITech stuff is making a push after some earlier hiccups. I also like the AEM stuff but that seems aimed more towards the Tuner crowd. Get some good books on EFI and start reading ... there's lots of knowledge base on sensors and system interaction that you have to get up to speed on just so you have an idea what all the acronyms mean and how all the little things work together as an integrated system. There are lots of frustrating little places where things can go wrong with EFI so jumping in for the first time can be difficult. FastMan has lots of experience with EFI and can help you get back on track when you start to get lost. AndyF has really been working hard on EFI projects and is making parts to help with conversion so he's an excellent resource. Jerry at SDConcepts.com also has some nice parts. And dotymi.com has some pulleys and sensor mounts. All the parts are out there, you just need to close your eyes, hold your breath and make the leap!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: Jeepmon]
#2389777
10/19/17 12:38 PM
10/19/17 12:38 PM
Triple Threat
Renton Washington
I'd bolt a different Carb on it long before I attempted that switch. We have 1 person in D6 with Holley EFI on their 145mph SST car and he has told me it is a struggle to make it work.
