Vacuum pump to use #2389471
10/18/17 07:45 PM
10/18/17 07:45 PM
nc
E
earthmover Offline OP
E
nc
Looking at adding a pump to the new motor..heard good things about g z motorsports pump but which kit you guys using..
512 lo deck
Wisco 14.1 piston
Billet rods
Ohio crank
Going with a custom cut cam for nos
Indy 1 heads clean up bigger valve
1050 dom carb
Custom fogger system t and d 1.6 rockers
Re: Vacuum pump to use [Re: earthmover] #2389482
10/18/17 08:22 PM
10/18/17 08:22 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Star is probably the best for the money, Moroso here...
Re: Vacuum pump to use [Re: earthmover] #2389485
10/18/17 08:24 PM
10/18/17 08:24 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Star or Moroso.
Re: Vacuum pump to use [Re: CMcAllister] #2389500
10/18/17 08:45 PM
10/18/17 08:45 PM
oregon
greendart408 Offline
oregon
Star machine here, best it gets.
Re: Vacuum pump to use [Re: earthmover] #2389525
10/18/17 09:30 PM
10/18/17 09:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use GZ. Nice product, GREAT customer service.
http://www.gzmotorsports.com/
Doug
Re: Vacuum pump to use [Re: dvw] #2389531
10/18/17 09:36 PM
10/18/17 09:36 PM
nc
E
E
nc
Star stuff looks great but do you have to buy all the extra stuff..belt mount tank ..
I've heard great things about g z motorsports pump
Re: Vacuum pump to use [Re: earthmover] #2389533
10/18/17 09:38 PM
10/18/17 09:38 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
I have a GZ pump on My Duster and It works great. You won't be disappointed.
Re: Vacuum pump to use [Re: earthmover] #2389546
10/18/17 09:59 PM
10/18/17 09:59 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I have a Moroso 4 vane. Works well. Easy to install.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Vacuum pump to use [Re: earthmover] #2389621
10/19/17 12:00 AM
10/19/17 12:00 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Best bang for the buck is GZ for sure.
Re: Vacuum pump to use [Re: earthmover] #2389788
10/19/17 12:49 PM
10/19/17 12:49 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Star is top shelf, but you don't have to buy anything but the pump if you like. All the other stuff can come from anyone. Star has the vacuum regulator built in, and moroso's is at additional cost, so add that in your comparison.
Re: Vacuum pump to use [Re: earthmover] #2389792
10/19/17 12:57 PM
10/19/17 12:57 PM
an8sec70cuda Offline
I've had an Aerospace pump and it was crap.
I now have a 4 vane Moroso and like it a lot. MUCH better than the Aerospace.
Star is supposedly top shelf, but pricy. I've heard nothing but good things about the GZ pumps.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vacuum pump to use [Re: earthmover] #2389806
10/19/17 01:22 PM
10/19/17 01:22 PM
I have the big GZ pump on my 505 C.I. low deck bracket motor, it barely pulls 5 inches revved up in nuetral work down
I have bought but not tried a Moroso three and another four vane pump, hopefully one of them will pull more luck
All three where used so maybe I need to return the GZ to them to check it out, I called them and they say it should pull more shruggy
Re: Vacuum pump to use [Re: earthmover] #2389810
10/19/17 01:27 PM
10/19/17 01:27 PM
AndyF Offline
AndyF  Offline
I just did some dyno testing with the new Star pump. Very nice pump and great guy to talk to on the phone. He really knows his stuff. I also highly recommend getting the Star intake/exhaust tank. It is a puke tank and an air/oil separator tank all in one.
Re: Vacuum pump to use [Re: earthmover] #2389811
10/19/17 01:28 PM
10/19/17 01:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
One of the drag week small block nitrous guys put 20,000 miles on a Morosso pump on a 1000HP nitrous small block before he felt it needed rebuilt. That is the route I will go when I get ready to go to a vacuum pump.
68 Barracuda Formula S 340
Re: Vacuum pump to use [Re: earthmover] #2389922
10/19/17 05:45 PM
10/19/17 05:45 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Moroso's are great quality pump. Mine has been flawless and I think MoparRich gave it to me pretty cheap a LONG time ago...
Re: Vacuum pump to use [Re: Dave Hall] #2389924
10/19/17 05:49 PM
10/19/17 05:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have the newer Moroso 4 vane on my Hemi it didn't pull as much or make as much power as we were expecting but it still does the job & is about half the price of a Star pump. I should have gone with a Star.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Vacuum pump to use [Re: earthmover] #2389949
10/19/17 06:32 PM
10/19/17 06:32 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
This one will work great for you.
Star Sportsman
Re: Vacuum pump to use [Re: earthmover] #2389971
10/19/17 07:16 PM
10/19/17 07:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Star or Moroso FTW!!
Re: Vacuum pump to use [Re: earthmover] #2390064
10/19/17 10:52 PM
10/19/17 10:52 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have a Moroso four vain now and it works very well.
However I have had a GZ in the past and like everyone has said, very good customer service.
Bill
Re: Vacuum pump to use [Re: 340Cuda] #2391050
10/22/17 01:59 AM
10/22/17 01:59 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I run an old 3 vain moroso with a 5 stage moroso dry sump pump, the combo together pulls 19-20" of vacuum.. just picked up a product engineering vacuum pump with all the drive pulleys for the pump and mandrel... dose anyone have any experience with the PE. pump?
