replacing my factory motor mounts #2389209
10/18/17 11:20 AM
10/18/17 11:20 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
anyone has any ideas on what other motor mounts to recommend. 383 b body.thanks
Re: replacing my factory motor mounts [Re: moparpro] #2389222
10/18/17 11:40 AM
10/18/17 11:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Use polys.they dont break i have Imperal services in my 65.rocky
Chrysler Firepower
Re: replacing my factory motor mounts [Re: moparpro] #2389251
10/18/17 12:16 PM
10/18/17 12:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are at least three different motor mounts used on a B body with a B engine, depending on year.
Would you like us to guess which one you need?
Don't be the exception.
Re: replacing my factory motor mounts [Re: moparpro] #2389321
10/18/17 02:51 PM
10/18/17 02:51 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Yes but lots of people making poly mounts.Early ones like my 65 were the hardest to find in poly.Now they are pretty common.I agree a year would help but its not necessary to say use polys.Most new rubber are junk. Rocky
Chrysler Firepower
Re: replacing my factory motor mounts [Re: moparpro] #2389340
10/18/17 03:15 PM
10/18/17 03:15 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
If it's a stock engine I don't think you need poly and you will feel more vibration from them. I'm speaking from experience. I've had both poly and stock rubber mounts and I can feel the difference. But yes, they will last a lot longer in poly, and you may want to get poly if you have a HP engine. Check energy suspension and prothane. I've bought from both.
Facts are stubborn things.
Re: replacing my factory motor mounts [Re: moparpro] #2389345
10/18/17 03:19 PM
10/18/17 03:19 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I have had good luck with Mity Mounts, cheaper than poly but still pricey compared to stock rubber.
Re: replacing my factory motor mounts [Re: T2R9] #2389410
10/18/17 05:13 PM
10/18/17 05:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not available for 65 and earlier B's
Re: replacing my factory motor mounts [Re: moparpro] #2389452
10/18/17 06:59 PM
10/18/17 06:59 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
You could also see if anyone has NOS ones. You know they'll be good quality if the rubber hasn't dried out.
Re: replacing my factory motor mounts [Re: larrymopar360] #2389476
10/18/17 08:00 PM
10/18/17 08:00 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
check this out A half hour job.....
Re: replacing my factory motor mounts [Re: moparpro] #2389527
10/18/17 09:33 PM
10/18/17 09:33 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: replacing my factory motor mounts [Re: bee1971] #2389598
10/18/17 11:14 PM
10/18/17 11:14 PM
IN
ahy Offline
ahy  Offline
IN
I would choose poly for anything as current rubber quality seems very poor. Thru bolt or interlocking type at least on driver's side if you will run it hard.
I have a 15 YO set of Schumacher poly mounts and no issues on a warm 496.
Re: replacing my factory motor mounts [Re: ahy] #2389733
10/19/17 10:29 AM
10/19/17 10:29 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
what about schumacher eng mount kit has anyone tried these and what experience have you had with them.thanks
Re: replacing my factory motor mounts [Re: ratroaster] #2390182
10/20/17 03:07 AM
10/20/17 03:07 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
That's exactly what I did on Kayse's 69 factory 383 Dart GTS. up
I had seen the post about doing that on here before.
