02/28/09 04:02 PM
02/28/09 04:02 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I baught a 340 out of a wreck 71 4spd Cuda should it have X or J heads?
Re: 71 340 [Re: Bishop] #238918
02/28/09 04:09 PM
02/28/09 04:09 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Re: 71 340 [Re: Morty426] #238919
02/28/09 04:21 PM
02/28/09 04:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Right, most would have J heads although it's possible it might have some with another letter. The "593" X-heads were being phased out in early 1970 and replaced with the "915" heads, some 593 heads made it onto 70 model year cars as well as a multitude of other letters cast into the same "915" heads; U,O,Z,J, etc. In fact some cars came with two different letters on the same engine, example one X head and one J head.
By the time 1971 production began it was a pretty safe bet that you would get "915" with the J heads.
Re: 71 340 [Re: ScottSmith_Harms] #238920
03/01/09 01:47 AM
03/01/09 01:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
What's the partial VIN# & is it orange or blue??
Re: 71 340 [Re: 6bblgt] #238921
03/01/09 09:01 PM
03/01/09 09:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Most likely j's with 2.02 intake size, April 2'nd build on my car orange, with 2.02 j's.
Re: 71 340 [Re: ademon] #238922
03/02/09 02:00 AM
03/02/09 02:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A, B or E body & which plant?
Re: 71 340 [Re: 6bblgt] #238923
03/02/09 10:58 AM
03/02/09 10:58 AM
New Jersey Bada Bing
bremotorsports Offline
And not only that:
Did the engine originate from the Windsor Plant (GW on the front of the block) or Mound Road Plant (GM on the front of the block)?
Bill Rolik
Re: 71 340 [Re: bremotorsports] #238924
03/02/09 11:10 AM
03/02/09 11:10 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
A body, Hamtramck. Bill this engine has all kinds of odd markings on the front drive side, When your free some time i'd like to give you a call to talk to you about it. Was their a strike at a plant making the 340's in 71? Mike
Re: 71 340 [Re: ademon] #238925
03/02/09 11:44 AM
03/02/09 11:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
ademon,
I think he's lokking for the info contained in this stamping on the front of the block, drivers side just under the head deck surface.
Re: 71 340 [Re: ScottSmith_Harms] #238926
03/02/09 02:25 PM
03/02/09 02:25 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Thanks for talking with me Bill, Your right after pulling the engine out under my bench it does have a very faint W after the G so it does read
GW340P33980351 X maltise cross and then a A4 under it just like in Scotts pic, i measured all the bores with a telesopic gauge and then measured it with my calipers and they all look standard at 4.04 definatly not .020 or bigger on the bores could be .005 as using calipers not as acurate. here are some pic's don't think the closeup will show with my camera. Thanks Mike
P.S. So mistery is why 11/16/70 assy in a 4/2/71 Demon 340 still continues?
Re: 71 340 [Re: ademon] #238927
03/02/09 02:27 PM
03/02/09 02:27 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
another
Re: 71 340 [Re: ademon] #238928
03/02/09 02:30 PM
03/02/09 02:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
another pic
Re: 71 340 [Re: ademon] #238929
03/02/09 02:38 PM
03/02/09 02:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Should the engine parts like intake and carb , dist, be 30-90 days before the engine asy date or the car build date?
Re: 71 340 [Re: ademon] #238930
03/02/09 02:39 PM
03/02/09 02:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, the block I posted as an example has a 9-24-1970 casting date.
Funny, my block (assembled on October 16th) is my dads birthday, and your block (assembled November 16th) is my birthday.
Re: 71 340 [Re: ademon] #238931
03/02/09 02:41 PM
03/02/09 02:41 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
last one
Re: 71 340 [Re: ScottSmith_Harms] #238932
03/02/09 02:44 PM
03/02/09 02:44 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Generally speaking- the engine assembly date
Re: 71 340 [Re: ScottSmith_Harms] #238933
03/02/09 09:39 PM
03/02/09 09:39 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
My birthday is October 9th if someone would like to send me a block.
logan426
