Page 3 of 3 1 2 3
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2388920
10/17/17 07:48 PM
10/17/17 07:48 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
12.17 best first time out earlier this year.
Since then, mildly ported the heads, changed cam and springs and fresh valve job. Swapped from single plane Mopar intake to air gap. Milled heads to raise compression up to around 10.4 to 1
Thats the major stuff. Not much really when you add it all up. The rest is just tinkering with timing, jetting, getting front end alignment from way off to pretty close. And finally swapping to radials.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: OUTLAWD] #2388945
10/17/17 08:34 PM
10/17/17 08:34 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Milan is a special case...haha
I believe the 60' beams are suspect...Somehow I have better short times at Milan, even though the track prep is normally worse. I am not the only one with similar results, a couple friends run points there and have said the same thing compared to other tracks in the area.
My husband and I were wondering the same about Milan. We still had a better sixty foot there than at Shakedown at Norwalk, where the track prep was set on kill...??
I'll be there in a 66 Plymouth Belv.
Need any jets/bleeds? I have 2 950 HPs on the shelf, always picked up from 750 to 950
I'll look for you! I'll be in a '65 Dart. We should be good on the jets, we have a complete set in our trailer. Thanks for the offer! Hopefully we'll see you tomorrow.
Re: Swapping to drag radials today, test tonight [Re: dustergirl340] #2388962
10/17/17 09:01 PM
10/17/17 09:01 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Learned ny lesson from the guru's on here. Even the 318 motor i had in the white Duster liked a 950 a tenth better than a 750.
Same thing with my current car. 750 slowed it down about .12 over a 950.
If both your carbs are dialed in, the bigger one will be faster
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2388993
10/17/17 09:36 PM
10/17/17 09:36 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
This is also a 318 and we're hoping it likes the 950 too! Will report results tomorrow evening.
Page 3 of 3 1 2 3
