Aftermarket Throttle Cable #2388616
10/17/17 10:38 AM
10/17/17 10:38 AM
E
earlymopar Offline OP
E
I'm looking for an aftermarket "universal" throttle cable that will fit this style of pedal. Everything I have seen so far has a clevis style on the pedal side of the cable. When I find a cable that has the correct end for this pedal, the opposite end is set up for throttle body injection whereas I have an AFB.
Re: Aftermarket Throttle Cable [Re: earlymopar] #2388622
10/17/17 10:51 AM
10/17/17 10:51 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, every mopar throttle cable from the muscle car era that I have seen is designed to work with that type pedal and an AFB, the clevis hooks on a stud at the carb and the ball end fits the pedal.
So I am not sure what you need.
Don't be the exception.
Re: Aftermarket Throttle Cable [Re: earlymopar] #2388771
10/17/17 03:23 PM
10/17/17 03:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I used a Lokar cable and it worked fine with that type of pedal.
68 Barracuda Formula S 340
Re: Aftermarket Throttle Cable [Re: earlymopar] #2388850
10/17/17 05:18 PM
10/17/17 05:18 PM
IL
furious70 Offline
furious70  Offline
IL
mancini has a couple different kinds of cables at different price ranges
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Aftermarket Throttle Cable [Re: earlymopar] #2388959
10/17/17 08:58 PM
10/17/17 08:58 PM
E
E
Thanks guys.
Just for clarification, This is a non-Mopar pedal and the ball end of the cable does not engage the hole directly. There is a plastic bushing that gets pressed into the hole and the ball pulls on the pedal via the bushing.
I've found what I need for both the cable and the bushing.
- EM
Re: Aftermarket Throttle Cable [Re: earlymopar] #2389174
10/18/17 09:18 AM
10/18/17 09:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Lokar cable will come with the clevis style attachment at the throttle end, but it is held on by a ball. You just pull the cable through the outer sheath, and remove the clevis which then you just use the ball on the cable end. I think they have different ends at the carb. The nice thing is you can cut the cable to the length you want.
Link to photo of ends.
http://www.lokar.com/product-pgs/throttl...carbend-fit.jpg
Re: Aftermarket Throttle Cable [Re: 451Mopar] #2389191
10/18/17 10:24 AM
10/18/17 10:24 AM
E
E
You are right 451. I have a Lokar cable from an earlier project and found that to be the case. Contrary to the earlier comment, the clevis is not on the carburetor-side on many cables.
- EM
