Backfiring through the exhaust #2388499
10/17/17 12:39 AM
10/17/17 12:39 AM
San Angelo, Texas, U.S.A.
1968RR Offline OP
1968RR  Offline OP
I've had the same set-up for years with few changes: Indy SR-headed 440, with Mallory/Hyfire 6AL ignition box (mounted under the hood), MSD coil, Mallory distributor. The only recent change was a couple of months back when I swapped out my 0.031" Holley squirter for a 0.035" squirter to help with a slight off-idle bog (I don't believe that this is the culprit).
The car has been having some kind of strange starting issues lately. The battery will seem near-dead after sitting for a few days, and will sometimes die before I can get the engine running. The battery's only 4 years old, and didn't seem to have any issues when I recently put it in my truck.
Out of the blue, the engine started backfiring through the exhaust yesterday. At first, I thought that it was loose plug wires, but they checked out. I also pulled all of the plugs and the distributor cap, but everything looks good. I tested the coil's resistances and they were 0.8 ohms across the primary and 7500 ohms across the secondary (higher than the advertised 4500 ohms).
I could be wrong, but I'm convinced that it's an ignition problem. Other than the backfires, the engine seems strong while running with the car in park. The backfires aren't consistent. If I bring the engine up to about 2500 rpm I'll get a loud backfire about every 30 seconds.
Any idea what I should check next? ...pull the valve cover? ...check compression?
Thanks in advance for any help?
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Backfiring through the exhaust [Re: 1968RR] #2388518
10/17/17 01:03 AM
10/17/17 01:03 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
fouled spark plug, that is what I would check 1st.
Re: Backfiring through the exhaust [Re: 1968RR] #2388522
10/17/17 01:09 AM
10/17/17 01:09 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
My 511 is doing the same thing. I think its a bad plug. Gonna change plugs tomorrow and see if it goes away. Mine pops out exhaust while at idle in gear only
Re: Backfiring through the exhaust [Re: 1968RR] #2388528
10/17/17 01:22 AM
10/17/17 01:22 AM
Az
Crizila Offline
Crizila  Offline
Az
#1 on the hit parade should be to get the battery problem fixed. Start with the battery - charge it and load test it. Then check to see that the charging system is working - 13.8 to 14.2 with the battery fully charged. Next check for an excessive amp draw with the key off. If that all checks out, your back fire problem is not related to the above ( based on what you have already checked). First thing to check is for exhaust leaks at the header flange.
Fastest 300
Re: Backfiring through the exhaust [Re: 1968RR] #2388562
10/17/17 03:34 AM
10/17/17 03:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree to make sure its a good strong battery. Also when does it backfire like when stepping on the gas or when letting off the gas ? Ron
Re: Backfiring through the exhaust [Re: 1968RR] #2388563
10/17/17 03:37 AM
10/17/17 03:37 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Exhaust leak?
Re: Backfiring through the exhaust [Re: 1968RR] #2388595
10/17/17 08:53 AM
10/17/17 08:53 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Had the same problem after chasing it through the charging system found the header gasket blow drivers side. Replaced and all was well... good luck
Re: Backfiring through the exhaust [Re: 1968RR] #2388596
10/17/17 09:01 AM
10/17/17 09:01 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Had a bud with intermittent miss and it was his plug wires gone bad. We opened the hood at night, put the car in drive and brake stalled it up against the converter to load the engine. You could see the spark jump to ground and it would start missing.
Re: Backfiring through the exhaust [Re: 1968RR] #2388604
10/17/17 09:47 AM
10/17/17 09:47 AM
Iceland
BadMoonRacer Offline
Iceland
After dark, with the car running in the garage; turn all lights off and watch all spark plug wires and the ign ystem. If they are leaking you´ll see it. Been there done that.
Ragnar in Iceland.
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Backfiring through the exhaust [Re: 1968RR] #2388606
10/17/17 09:58 AM
10/17/17 09:58 AM
1968RR Offline OP
1968RR  Offline OP
The plugs looked good, but I can go ahead and swap them out and see if anything changes. I'll also swap my truck battery in and see if that makes a difference.
I can't tell if it is backfiring through the same side of the engine each time or not. I'll also check and see if I've got an exhaust leak near the heads.
Thanks for the input.
Re: Backfiring through the exhaust [Re: 1968RR] #2388610
10/17/17 10:25 AM
10/17/17 10:25 AM
an8sec70cuda Offline
Parts store batteries typically only last 4-5 years. 5 if it's a good one. So get a new battery first and make sure your charging system is working.
If the plugs don't fix it and your wires check good, it's possible you damaged the MSD box w/ the low voltage. MSD boxes don't deal too well w/ low voltage when cranking and trying to run. I've had this happen a couple of times.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Backfiring through the exhaust [Re: 1968RR] #2388688
10/17/17 12:32 PM
10/17/17 12:32 PM
warren, mich.
dwayne welder Offline
warren, mich.
I have found that on MSD distributor that the "pic-up Coil " in the distributor is the problem! Had that problem twic this year on two different engines! Good Luck
Re: Backfiring through the exhaust [Re: 1968RR] #2388748
10/17/17 02:32 PM
10/17/17 02:32 PM
IL
furious70 Offline
furious70  Offline
IL
I agree low voltage and 6A boxes don't like each other. Also, where is the 6A located? Mine have always been pretty heat sensitive and act up with they get hot or have been heat cycled a bunch.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Backfiring through the exhaust [Re: 1968RR] #2388767
10/17/17 03:18 PM
10/17/17 03:18 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Header loose or bad header gasket
Re: Backfiring through the exhaust [Re: 1968RR] #2389010
10/17/17 10:14 PM
10/17/17 10:14 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Changed plugs today. Exhaust pop gone. Runs smoother to. All were dark.
Re: Backfiring through the exhaust [Re: 1968RR] #2389056
10/17/17 11:38 PM
10/17/17 11:38 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Well I have the same problem. Battery is good, engine starts right up . It has a miss . Pops through the exhaust going down the road . Not a gasket leak , put in new plugs, no change, started in the garage at night with the lights off , reved engine with no spark tracing anywhere. Used those wire testers with the lights in them to check to see if the wires were firing at the plug , all good, Inspected the cap, checked the point gap,and timing . Finally did a compression check. All cylinders were 150 except 2 which were 145. Now what did I miss?
Re: Backfiring through the exhaust [Re: 1968RR] #2389059
10/17/17 11:43 PM
10/17/17 11:43 PM
1968RR Offline OP
1968RR  Offline OP
I was swapping out spark plugs, just to make sure that one of the plugs hadn't gone bad, and decided to check the plug wires while I was at it. The multimeter showed that two of the eight had no continuity. shock
...not 100% sure that that's what is causing the backfires (could still arc across whatever gap exists), but they definitely need to be replaced.
Re: Backfiring through the exhaust [Re: rowin4] #2389089
10/18/17 12:49 AM
10/18/17 12:49 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Had the same problem yrs ago. I grounded the block directly to the battery. I put a terminal strip under the dash, grounded everything to it i.e.,tach, ing box & gauges & ran it directly to the battery. No more miss.
Re: Backfiring through the exhaust [Re: 1968RR] #2389113
10/18/17 01:45 AM
10/18/17 01:45 AM
WI
Brewzer67 Offline
Brewzer67  Offline
WI
I would check the float bowls and float needles to see if there is any debris in either one. Or possibly a leak near one on the collectors. Something has to be putting enough extra fuel or oxygen into the exhaust system to produce the backfire. Maybe a rear float set too high and you are getting a splash of fuel into the intake on bumps or decel? A bad power valve will do this but usually that will show up as a super rich mixture and foul plugs.
Re: Backfiring through the exhaust [Re: 1968RR] #2389114
10/18/17 01:45 AM
10/18/17 01:45 AM
rowin4 Offline
rowin4  Offline
I did notice the small ground strap was broken from the engine to frame. Do you think that could be the problem?
