what head gasket are you using #2388299
10/16/17 06:56 PM
10/16/17 06:56 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
hi po 383 eng,not felpro but something better not cork made.thanks
Re: what head gasket are you using [Re: moparpro] #2388356
10/16/17 08:25 PM
10/16/17 08:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
FelPro is fine for that. You could buy Cometic I guess...
Re: what head gasket are you using [Re: moparpro] #2388362
10/16/17 08:38 PM
10/16/17 08:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure what "not cork made" means.
Don't think anyone makes a cork head gasket
Unless you are confusing valve cover gasket, which can be had in cork, with a head gasket?
Don't be the exception.
Re: what head gasket are you using [Re: Supercuda] #2388541
10/17/17 01:59 AM
10/17/17 01:59 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
God, that brings back memories from behind the parts counter. Sold a guy a pair of head gaskets. Couple of days later he calls in saying he can't figure out how they fit... he has been trying for two days and can't make them work. Tell him to bring the head in and we'll see what the problem is. An hour later I see him walking in and I can barely keep from laughing. He is carrying a valve cover and has the head gaskets all mashed and greased up from trying to get then to fit inside the valve covers. Took the head gaskets back and handed him a new pair of valve cover gaskets, no charge. Turned the head gaskets in for warranty. All the parts guys had a good laugh that day. wrench
Re: what head gasket are you using [Re: moparpro] #2388572
10/17/17 03:56 AM
10/17/17 03:56 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Man! I was really trying to give a short, respectful response and not go there. There are new guys you know. Teach 'em right and they are an asset to the later community and prob. find out you may have more in COMMON than you think! up
Honestly I did find it funny but I just didn't have to go there. Carry on...
Re: what head gasket are you using [Re: Dave Hall] #2388586
10/17/17 06:38 AM
10/17/17 06:38 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If it is valve cover gaskets, fel pro blue cork/ rubber have been the best for me. The red silicone and black rubber gaskets will not take the heat from the exhaust manifolds sitting one inch away.
Head gaskets I still use steel shim, I think I have one set of the old McCord / Mopar Performance gaskets left...factory iron heads, not aluminum.
Re: what head gasket are you using [Re: sthemi] #2388612
10/17/17 10:28 AM
10/17/17 10:28 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
sorry guys just made a mistake i know the difference,just made a mistake.
Re: what head gasket are you using [Re: moparpro] #2388628
10/17/17 10:57 AM
10/17/17 10:57 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wasn't trying to be an ass, but I can't answer a question if I don't know what it is.
I like these
Re: what head gasket are you using [Re: moparpro] #2388732
10/17/17 02:04 PM
10/17/17 02:04 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Check with Superformance for valve cover gaskets. They've got good gasket options now. Mancini stocks alot of their stuff I believe.
Re: what head gasket are you using [Re: 80fbody] #2388853
10/17/17 05:20 PM
10/17/17 05:20 PM
IL
furious70 Offline
furious70  Offline
IL
+1
but I used .020 factory shims on my boosted (5psi) 383 smile
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: what head gasket are you using [Re: moparpro] #2389312
10/18/17 02:09 PM
10/18/17 02:09 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I like the cork,I have good luck with them. Glue them to the cover with a thin film of sealer. VERY lighty bolt to the head just so the gasket seats against the cover. Let it dry then install for real dry on the head side. Have removed the covers many times never leaks. Just don't over tighten them.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
