Re: what head gasket are you using
[Re: moparpro]
#2388362
10/16/17 08:38 PM
10/16/17 08:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure what "not cork made" means.
Don't think anyone makes a cork head gasket
Unless you are confusing valve cover gasket, which can be had in cork, with a head gasket?
[Re: Supercuda]
#2388541
10/17/17 01:59 AM
10/17/17 01:59 AM
Posts: 1,820 South Bend
John Brown
South Bend
Unless you are confusing valve cover gasket, which can be had in cork, with a head gasket? God, that brings back memories from behind the parts counter. Sold a guy a pair of head gaskets. Couple of days later he calls in saying he can't figure out how they fit... he has been trying for two days and can't make them work. Tell him to bring the head in and we'll see what the problem is. An hour later I see him walking in and I can barely keep from laughing. He is carrying a valve cover and has the head gaskets all mashed and greased up from trying to get then to fit inside the valve covers. Took the head gaskets back and handed him a new pair of valve cover gaskets, no charge. Turned the head gaskets in for warranty. All the parts guys had a good laugh that day.
[Re: moparpro]
#2388572
10/17/17 03:56 AM
10/17/17 03:56 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Man! I was really trying to give a short, respectful response and not go there. There are new guys you know. Teach 'em right and they are an asset to the later community and prob. find out you may have more in COMMON than you think! Honestly I did find it funny but I just didn't have to go there. Carry on...
[Re: Dave Hall]
#2388586
10/17/17 06:38 AM
10/17/17 06:38 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
If it is valve cover gaskets, fel pro blue cork/ rubber have been the best for me. The red silicone and black rubber gaskets will not take the heat from the exhaust manifolds sitting one inch away.
Head gaskets I still use steel shim, I think I have one set of the old McCord / Mopar Performance gaskets left...factory iron heads, not aluminum.
[Re: moparpro]
#2388628
10/17/17 10:57 AM
10/17/17 10:57 AM
Supercuda
About to go away
About to go away
up yours
Wasn't trying to be an ass, but I can't answer a question if I don't know what it is. I like these
[Re: 80fbody]
#2388853
10/17/17 05:20 PM
10/17/17 05:20 PM
Posts: 2,255 IL
furious70
IL
Check with Superformance for valve cover gaskets. They've got good gasket options now. Mancini stocks alot of their stuff I believe. +1 but I used .020 factory shims on my boosted (5psi) 383
70 Sport Fury 68 Charger 69 Coronet 72 RR
