Re: Indy head external oiling
[Re: rebel]
#2386499
10/12/17 09:00 PM
10/12/17 09:00 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
You could try it without them and add them after later if needed. I use a .039 hole size on all my Indy headed motors with Harland Sharp and T&D single shaft roller rocker arms Are you planning on running a solid roller cam with it? If so those valve springs need all the oil they can get on them to help keep them cool How big is the oil pan capacity ?
[Re: DoubleD]
#2387428
10/14/17 06:19 PM
10/14/17 06:19 PM
Posts: 4,647 aotearoa
rebel
aotearoa
With Harland sharpes you absolutely need to run restricted oil lines - or you will be pumping way to much oil to the top of the heads and taking away from your bottom end. Usually a .040 is good - but no more than the .060 this is what i was thinking. i used HS on my SB & as soon as i installed them i noticed a drop in oil pressure. the big test will be the prelube on the drill which will happen this week. got the engine sitting back in the car last night. a few more nights n i'll have all the wiring n plumbing done ready for launch.
[Re: DoubleD]
#2387700
10/15/17 12:34 PM
10/15/17 12:34 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
With Harland sharpes you absolutely need to run restricted oil lines - or you will be pumping way to much oil to the top of the heads and taking away from your bottom end. Usually a .040 is good - but no more than the .060 Same here. Lost significant oil pressure until I dropped down to around a .045" or .040" restriction to get my oil pressure back up to where I started. Still left plenty of oil to the shafts for the HS rockers.
[image][/image]
[Re: sgcuda]
#2388491
10/17/17 12:16 AM
10/17/17 12:16 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You can run .015 per side and still oil more than necessary...
Brian Hafliger
