Re: Indy head external oiling
[Re: rebel]
#2386499
10/12/17 09:00 PM
10/12/17 09:00 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
You could try it without them and add them after later if needed. I use a .039 hole size on all my Indy headed motors with Harland Sharp and T&D single shaft roller rocker arms Are you planning on running a solid roller cam with it? If so those valve springs need all the oil they can get on them to help keep them cool ![work work](/ubbthreads/images/graemlins/custom/work.gif) How big is the oil pan capacity ?
[Re: DoubleD]
#2387428
10/14/17 06:19 PM
10/14/17 06:19 PM
Posts: 4,647 aotearoa
rebel
aotearoa
With Harland sharpes you absolutely need to run restricted oil lines - or you will be pumping way to much oil to the top of the heads and taking away from your bottom end. Usually a .040 is good - but no more than the .060 this is what i was thinking. i used HS on my SB & as soon as i installed them i noticed a drop in oil pressure. the big test will be the prelube on the drill which will happen this week. got the engine sitting back in the car last night. a few more nights n i'll have all the wiring n plumbing done ready for launch.
[Re: DoubleD]
#2387700
10/15/17 12:34 PM
10/15/17 12:34 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
With Harland sharpes you absolutely need to run restricted oil lines - or you will be pumping way to much oil to the top of the heads and taking away from your bottom end. Usually a .040 is good - but no more than the .060 Same here. Lost significant oil pressure until I dropped down to around a .045" or .040" restriction to get my oil pressure back up to where I started. Still left plenty of oil to the shafts for the HS rockers.
[image][/image]
[Re: sgcuda]
#2388491
10/17/17 12:16 AM
10/17/17 12:16 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You can run .015 per side and still oil more than necessary...
Brian Hafliger
