Re: Cost vs benefits of a counterweighted crankshaft
[Re: Hemi_Joel]
#2388415
10/16/17 10:01 PM
10/16/17 10:01 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Obviously, the lesser you pay for a CCW crank, the more worth it it becomes. Ohio crank sells a billet 4.5 for $1650. I would assume that has center counterweights. Or you could look for a good used alcohol crank. I scored a used moldex billet stroker with center counter weights, checked straight and crack free, for just over a grand. That was worth it in my opinion. Agreed. But not all alcohol cranks are CCW. The question is "Do I need this for a 1,000 hp N/A combo that is only going to turn around 7,000 rpm?" If I'm not spinning it to the moon, and I'm not boosting or adding nitrous to make 1,500+ hp, how necessary is a CCW crank? To me, changing out bearings at the end of the race season wouldn't be a big deal, if that's all there is. But if the engine runs smoother and develops more power due to less torsional twist, it might be something to consider.
[Re: sgcuda]
#2388436
10/16/17 10:50 PM
10/16/17 10:50 PM
Superfreak
Superfreak
A few months ago I got a price for ccw billet hemi crank from Bryant for $3024 and I thought that was a good price considering that the same crank from Callies was $4300. I know it does not answer your question but just a little tid bit on the pricing.
[Re: sgcuda]
#2388444
10/16/17 11:02 PM
10/16/17 11:02 PM
sgcuda
Ohio Crankshaft has billet CCW cranks for $1645. But is it necessary over their $720 4340 crank? Or is it overkill for what I am building?
[image][/image]
[Re: sgcuda]
#2388455
10/16/17 11:15 PM
10/16/17 11:15 PM
Superfreak
Superfreak
You are correct, just looked at there web site and $1645 for the hemi ccw billet crank. Would have to have a register cut on the back side. Most people running in that hp range are using a standard forged crank from what I have read.
[Re: sgcuda]
#2388463
10/16/17 11:23 PM
10/16/17 11:23 PM
Posts: 10,020 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Once you buy a ccw crank, you have a unit that should never fail. I cracked a 4.15 stroke crank at 100 runs, and upgraded to a Crower CCW made of 304m steel. Since you are pushing piston speed and crank loading pretty high with a 4.5 stroke and 7,000++ rpm, I would go CCW.
[Re: sgcuda]
#2388487
10/17/17 12:09 AM
10/17/17 12:09 AM
Superfreak
Superfreak
There is a good read from "Engine Labs" regarding crankshafts.
[Re: sgcuda]
#2388615
10/17/17 10:32 AM
10/17/17 10:32 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
For this build, I think it's overkill to go w/ a CCW crank. No downsides other than cost, but I don't think it needs it.
I'd love to hear more on the reasoning not to go over 4.5" stroke by those "people in the know" you referred to earlier.
[Re: sgcuda]
#2388881
10/17/17 06:24 PM
10/17/17 06:24 PM
crabman173
crabman173
So many great big CI engines run and make 1000HP without it If you are going to ask --call Charlie Buck in King NC He is in your hood and will have an opinion and answer based on probably more experience in big Mopars than anywhere else Can't go in that place that Marsh does not have a big Hemi or wedge Monster on the pump--They know!
[Re: sgcuda]
#2388998
10/17/17 09:44 PM
10/17/17 09:44 PM
Superfreak
Superfreak
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals.
[Re: ]
#2389032
10/17/17 11:08 PM
10/17/17 11:08 PM
sgcuda
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals. Well, since I don't want to run with anything larger than BBC journals, the billet piece is out. From the info I have gathered, I have learned that 1) aluminum rods will not clear the cam with crank strokes longer than 4.500" and 2) crank strokes longer than 4.500" will cause excessive piston skirt wear. Interesting enough, I have read somewhere about a new piston being made with an asymmetric skirt, favoring the major thrust side. Maybe just for this kind of build.
[Re: ]
#2389069
10/18/17 12:06 AM
10/18/17 12:06 AM
Posts: 31,077 Oregon
AndyF
Got a reply from Ohio Crank today and they said the billet can only be made with Chrysler journals. That doesn't seem to make sense. I can understand a forged crank only available in a certain journal size but billet is billet. It is all being machined anyway so all they have to do is punch a few buttons and then instant presto you have 2.200 rod journals. If I got an answer like that from a place claiming to make billet cranks I'd move on down the line. I'm pretty sure if you call Winberg or Bryant or some other place that makes billet cranks and ask them if they can make the cranks with different rod journals they'll tell you sure. They can probably make each journal a different size if you want to pay for it. Someone at Ohio Crank either doesn't know what they are talking about or else they aren't really billet cranks. Or perhaps the cranks are made by someone else and Ohio Crank just sells them......
