Vote for the Carb(s) I test on the Dyno! #2388314
10/16/17 07:26 PM
10/16/17 07:26 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
OK, sometimes I can't help myself from posting this sort of stuff... even when I probably shouldn't for a variety of reasons. None the less...
I have an ever-expanding collection of 4150-type carbs as listed below. As much as I'd like to throw each one on the engine dyno to see what's what, the reality of time constraints will likely limit testing to two, maybe 3, if any level of dialing in a particular carb is to be done.
In addition, one carb that absolutely needs to be in the subset being tested is the #1 carb in the list, because that's the last baseline I have and what was run successfully on my car in the past.
1. BG Race Demon RS set up w/ 1.42" venturi sleeves
=> previous tune as used on my car when it ran 10.5s as driven to the track
So... that means you can pick two (2) of the remaining carbs listed.
2. BG Gold Claw set up w/ 1.50" venturi sleeves
=> new & untested config
=> pushing the limit for venturi size w/ downleg boosters that I believe will work well on my car
3. QFT/Proform 1.45" venturi main body used as basis for complete carb
=> original boosters; new & untested
=> Basically a Proform "950" with a better tune
4. QFT/Proform 1.52" venturi main body used as basis for complete carb
=> BLP modified boosters; new & untested; this is the limit for venturi size w/ downleg boosters I'll try
=> comparable to a QFT Race-Q 1000, which Quick Fuel used to win the small-block class in the last BLP Carb Challenge held a few years ago
5. QFT/Proform 1.59" venturi annular booster main body used as basis for complete carb
=> comparable to a QFT Race-Q 1050-AN, which AndyF said has been the best performing 4150 carb he's tested so far
6a. Holley Ultra HP/XP 1.60" venturi carb re-fitted with Mark Whitener's custom annular boosters
=> purchased from AndyF 'cuz I thought it looked "interesting"
=> Dominic "Thumper Carbs" worked on the tune to make it more driveable vs its original dyno tune
6b. Same as #6a, only with Holley Ultra HP/XP 1.56" venturi main body blended out to 1.58" and equipped with the same 12-hole annular boosters as the #5 carb
=> Mark Whitener's flow testing of a variety of carbs showed the modified Ultra HP/XP 1.56" (1.58") venturi main body flowed noticeably better than Holley's 1.60" venturi body... so I decided to build one
Do your votes really count towards what I run? Ummmm... nope. laugh2
The final choices are still mine, but I'm interested in hearing people's feedback & thoughts on the subject, regardless. work
Before anyone says anything about it - right, no Dominators.
I'm A$$uming most people are familiar w/ my junk, as much as I've posted over the years.
If you're not, the $.05 tour will be brief:
- 440 street/strip car
- 3800#s w/ driver
- pump fuel... that'll probably need to get spiked w/ some race gas cuz the CR is now up to 11.5
- 4500-stall converter
- 4.10s
- 275/60R15 DOT drag radials
- Guess-timating the new combination will make... 650+ HP... and the car "should" be capable of running closer to 10.0s once sorted out
OK, back to all the other stuff I have to deal with. - Brad
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388320
10/16/17 07:33 PM
10/16/17 07:33 PM
AndyF Offline
AndyF  Offline
Well you're going to have to test them all at some point so you know what to keep and what to sell.
If it was me I'd test the carbs in order of how important the carbs are to you. If you paid a lot for them, or if you think they should be the best then test that one first. That way you test the stuff you care about most in your limited testing time. If you have some carbs that you don't really care about anymore then sell them now before you waste any time on them. If you can't sell a carb without trying it then you'll just have to try them all....
Seems to me you need to try 6a and 6b since you've recently invested money into them just to see if they are going to work. I'd think that those would be so close that one of those will get sold. I'm also going to guess that one of those carbs is the best of the litter.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388325
10/16/17 07:37 PM
10/16/17 07:37 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
carb #3 and carb 6b.
but andy has a point too, 6a and 6b would seem like a test that you would want to do...
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388329
10/16/17 07:47 PM
10/16/17 07:47 PM
AndyF Offline
AndyF  Offline
Another idea is to do a BOB and WOW test. This is something we always trained new engineers on. BOB is "best of the best" and WOW is "worst of the worst". It gives you a quick way to sort stuff out.
In this case you'll be guess which is the BOB and which is the WOW but even the guess can be informative. If what you think is the BOB turns out to make the same power as the WOW then that tells you something.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388336
10/16/17 07:55 PM
10/16/17 07:55 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
#5 is what I have on my 512 street car. so yeah test #5 smile
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388344
10/16/17 08:04 PM
10/16/17 08:04 PM
Washington
madscientist Offline
Washington
Send a carb to Dom and have him tune up it. Use that as your base carb.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388363
10/16/17 08:41 PM
10/16/17 08:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
Is this testing going to be on a engine dyno or chassis dyno?
Test the three biggest ones, #5 and 6A up devil
Are you going to change the jetting on all of them or not?
Re: Vote for the Carb(s) I test on the Dyno! [Re: madscientist] #2388365
10/16/17 08:46 PM
10/16/17 08:46 PM
BradH Offline OP
BradH  Offline OP
That would be 6a, as noted in the description. wink
Also, 6b is 6a with a main body swap, not two separate carburetors. That's why they're not listed as 6 & 7.
Re: Vote for the Carb(s) I test on the Dyno! [Re: Cab_Burge] #2388368
10/16/17 08:48 PM
10/16/17 08:48 PM
BradH Offline OP
BradH  Offline OP
Engine dyno.
Bringing lots of brass, but time is always a factor.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388384
10/16/17 09:16 PM
10/16/17 09:16 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Brad ,
#1 , 4 , 6b
#1 because it is a known unit .
#4 bigger venturi same style . I ran a HP1000,1.56 venturi , on my 440 . Very happy, more power than my BG 825
#6b , a little bigger again . But if #4 shows improvement this will then show if annular is better for your motor .
Then you will have to try them all again on the street / strip to confirm results .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388388
10/16/17 09:18 PM
10/16/17 09:18 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Marks boosters and Thumpers tune on #6A should be a good test against #5.
[image][/image]
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388394
10/16/17 09:25 PM
10/16/17 09:25 PM
Washington
Washington
Sorry, I flat missed that.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388460
10/16/17 11:22 PM
10/16/17 11:22 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi ,
i vote for trashing them all and using a holley 3 bbl !
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388480
10/16/17 11:51 PM
10/16/17 11:51 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
I vote for the 1050 QF carb with downleg boosters. That one was better than the BG 850 and just a handfull less HP than an 1150 Dominator on my build. up
Ron
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388531
10/17/17 01:37 AM
10/17/17 01:37 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
1, 5, 6a & b
Then, time permitting 2 or 4.
If they aren't "close" ootb...... It can really eat up dyno time trying to sort them out.
IMO, with limited dyno time available, if you bolt one on and it's just out to lunch...... I'd put that one aside and try a different one.
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388564
10/17/17 03:41 AM
10/17/17 03:41 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Dyno shmyno! Put them on a good, known car and figure it out. haha I'll go with the 6's! grin
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388698
10/17/17 12:49 PM
10/17/17 12:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The #6 still needed some work when I sent it to ya but figured you'd see what your combo needed to dial it in I just know it was stupid phatt across the board as delivered and killed my oil. Should be fun testing either way then of course in the car it will/may change as most seem to from my experience...........good luck either way....... thumbs
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2388703
10/17/17 12:57 PM
10/17/17 12:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
I made my picks, but I'm in agreement with Andy on this point...... Test the ones you think will be/want to be the best first.
Edit- after hearing Doms comments about the 6a being a little fat..... I guess I'd start out with the known quantity tune of the #1 carb.
No point in risking washing the rings down right off the bat.
I'd do the initial run it with the #1 carb, get it all warmed up, lash the valves, make a couple pulls ...... And hopefully that carb has a decent enough fuel curve to establish a baseline without having to do a bunch of tuning on it.
The next carb I'd try would be the 6a.
Re: Vote for the Carb(s) I test on the Dyno! [Re: fast68plymouth] #2389047
10/17/17 11:30 PM
10/17/17 11:30 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Brad,
What criteria are you planning to use to evaluate the carbs? Peak numbers, area under the curve, something else??
Re: Vote for the Carb(s) I test on the Dyno! [Re: BradH] #2389053
10/17/17 11:36 PM
10/17/17 11:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
What throttle blade size do these carbs have?
