4" 360 cranks #2388124
10/16/17 01:17 PM
10/16/17 01:17 PM
Western New York
sixpackbee Offline OP
Western New York
Who has the best 4" forged crank? Looking at Eagle, Scat, & Ohio.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 4" 360 cranks [Re: sixpackbee] #2388130
10/16/17 01:24 PM
10/16/17 01:24 PM
I've used a bunch of BB stroker cranks from Ohio Crankshafts with no bad results up They are made and processed, all machine work and heat treating, done here in the U.S. in Ohio work
Eagle and Scat not so is what I've been told on here many times shruggy
I've also used some cheaper Chinese imports, Scat cast steel SB stroker and several BB RPM brand stroker cranks in several motors with no problems either confused work
Re: 4" 360 cranks [Re: sixpackbee] #2388144
10/16/17 01:36 PM
10/16/17 01:36 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Give Bloomer performance a call. Nice stuff
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 4" 360 cranks [Re: sixpackbee] #2388146
10/16/17 01:42 PM
10/16/17 01:42 PM
P
Porter67 Offline
Porter67  Offline
P
4" forged crank
I think you will find they are all pretty decent, ive had more jacked ootb higher cost cranks then lower cost over the years.
K1 being the worst offender, 3 for 3.
Re: 4" 360 cranks [Re: sixpackbee] #2388163
10/16/17 02:13 PM
10/16/17 02:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The K1 I ran in my 408 is fine, no issues.
Re: 4" 360 cranks [Re: justinp61] #2388196
10/16/17 03:08 PM
10/16/17 03:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The only issue I had with my K1 crank was it was a little tight for my convertor huh. A few minutes with a flapper wheel fixed this issue. That engine went 9.60's in my duster and I will be building a better engine with another K1 crank I have sitting here over the Winter
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 4" 360 cranks [Re: sixpackbee] #2388212
10/16/17 03:37 PM
10/16/17 03:37 PM
gregsdart Offline
gregsdart  Offline
Check Molner, great parts.
Re: 4" 360 cranks [Re: sixpackbee] #2388222
10/16/17 03:54 PM
10/16/17 03:54 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I have an Ohio 4" in the 408. 250 passes so far and no issues. I'd buy another one.
Re: 4" 360 cranks [Re: sixpackbee] #2388265
10/16/17 05:20 PM
10/16/17 05:20 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I'm not sure those Ohio cranks are US made... anyone know for certain? My engine guy has had issues with them and told me not to bring them to his shop... he sez the quality control has been inconsistant.
I have a 3.79 Mopar Performance crank in my SB 383... comes from 1993 and it appears to be US made. Just got it back from the crank shop... had one journal repaired after it smoked two rods after being run with heavy oil and no warm up. The PO told me he paid $1800.00 for it back in the day...
Re: 4" 360 cranks [Re: Medlock51] #2388268
10/16/17 05:34 PM
10/16/17 05:34 PM
I question them on where the forging came from back in the early 2000s when they first started advertising in the National Dragster, they insisted that all their forging came from Ohio Forge shruggy scope
As far as quality control I've never had a issue with any of the ones (12) I bought and used shruggy
One of them is in my current bracket motor hammer up
Re: 4" 360 cranks [Re: Cab_Burge] #2388395
10/16/17 09:28 PM
10/16/17 09:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Does Ohio Forge own a factory in China? The answer they gave you could be technically correct and the forging still be from off shore.
Kevin.
Re: 4" 360 cranks [Re: Cab_Burge] #2388447
10/16/17 11:05 PM
10/16/17 11:05 PM
dogdays Offline
dogdays  Offline
I don't believe there is a company that is called Ohio Forge. I just did a literature search on all the forging companies in Ohio and not one of them looked like they forged automobile crankshafts. There is a brand of cheap Chinese power tools named Ohio Forge, but no relation.
When this topic came up a few years ago someone said he had received his Ohio Crank crankshaft in a box that said Newland. If you look that up you will find that the Newland Group is a Chinese company supplying higher performance parts to the American market.
I'm not complaining, because 90% of the advances in hot parts here in the US have been forced along by the sudden availability of stroker cranks and high quality connecting rods in such a variety that it's almost unheard of any more to not build a stroker. Bigger engines need better heads, better intake systems, more variety and better pistons, etc.
Ohio Crank is making money and employing American workers. Maybe they're just checking tolerances, maybe they're doing finish machine, I will never know. I'm just happy that we have much better options when building engines.
R.
Re: 4" 360 cranks [Re: sixpackbee] #2388799
10/17/17 04:04 PM
10/17/17 04:04 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Molnar or K1, IIRC Tom Molnar used to own K1??
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 4" 360 cranks [Re: FurryStump] #2388837
10/17/17 04:53 PM
10/17/17 04:53 PM
dogdays Offline
dogdays  Offline
Tom Molnar was part of the K1 startup, I believe he was designer at another high end hard part company before K1. Says on the website that he has more than 35 years doing cranks and rods.
Molnar left K1 to run his own business.
K1 was bought by Wiseco. Now they can sell you a complete rotating assembly.
It's easy to have your own crank and rod or cylinder head company nowadays. Just check out all the suppliers at alibaba.com I believe it's safe to say that any $800 or less crank, and any $600 and less set of rods, came out of China. You may or may not do finish machining or dimensional checking in the States. They'll laser etch or stamp or whatever your name on the rod and voila! You are a connecting rod company.
I'm not throwing mud at Tom Molnar. The Chinese designs are rather generic. I believe that Tom will add his input to get closer to what he wants. Plus his personal involvement in the company means the customer is at least two or three steps closer to top management.
R.
Re: 4" 360 cranks [Re: sixpackbee] #2388843
10/17/17 05:01 PM
10/17/17 05:01 PM
AndyF Offline
AndyF  Offline
Lots of choices. I've had good luck with SCAT, Molnar and K1. Sometimes it just depends on price and availability. If you are using JE pistons then you can buy a package deal from K1. If you order from Summit you can get free shipping so that saves you money. I'm set up as WD with Molnar so that saves money too.
Re: 4" 360 cranks [Re: sixpackbee] #2389235
10/18/17 11:54 AM
10/18/17 11:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Molnar would be my choice over anything but a Winberg or Bryant and those are hard for most of us to afford new.
Excellent customer service and good advice.
Bill
Re: 4" 360 cranks [Re: sixpackbee] #2389268
10/18/17 12:31 PM
10/18/17 12:31 PM
P
Porter67 Offline
Porter67  Offline
P
Ive posted before my most trouble free crank has been a simple eagle forged 4 inch crank, its in my sprayed street racer that runs 6.0s at the track.
The K1-s I had trouble with, one had a main way off and two others had mains so far each way I had to go .010 on them, however with K1 being a good product I got both of the worst K1-s from the same place, same time, that I didnt know was closing shop soon after my purchase and both cranks were dated, so maybe I got there off the shelf not so great ones or maybe even returns.
Just like anything, good machine work and proper assembly goes way further then the brand on most of our junk.
Re: 4" 360 cranks [Re: sixpackbee] #2389664
10/19/17 12:56 AM
10/19/17 12:56 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Molnar for me
RIP Monte Smith
