Aftermarket wiring kits #2388040
10/16/17 09:52 AM
10/16/17 09:52 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Morning All, anybody have any experience/comments on this?
http://www.ebay.ca/itm/American-Auto-Wir...725.m3641.l6368
Not much left of the original harnesses in my rebuild so looking at options.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Aftermarket wiring kits [Re: busboy] #2388064
10/16/17 10:56 AM
10/16/17 10:56 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I used an American Autowire Harness in my 1955 Plymouth and was very pleased with the quality. Everything was marked and the instructions/diagrams were great. I can't speak to this specific kit though. However, I did consider buying this one and adapting it to my '71.
Re: Aftermarket wiring kits [Re: busboy] #2388070
10/16/17 11:21 AM
10/16/17 11:21 AM
Idaho
Motor Mayhem Offline
Idaho
I recently installed that harness in a '69 roadrunner. It's a high quality kit that is versatile enough to accommodate multiple add-ons (electric fans, fuel injection, gear vendor controller, etc.) The fuse block mounts in the original location.
Re: Aftermarket wiring kits [Re: Motor Mayhem] #2388089
10/16/17 12:04 PM
10/16/17 12:04 PM
moparx Offline
moparx  Offline
make sure to use a quality crimping tool when you terminate the required ends of a "universal" type harness. the money spent, and the time taken to learn how to properly use it will have you feeling good when done, as opposed to swearing and tearing your hair out chasing problems when using the crimping tools that come with those $2.69, eleventybillion piece kits from elcheapistan freight. my opinion from repairing wiring nightmares over many, many, many years.
beer
Re: Aftermarket wiring kits [Re: busboy] #2389461
10/18/17 07:23 PM
10/18/17 07:23 PM
busboy Offline OP
busboy  Offline OP
Thanks for the replys all, sounds like it's a decent kit. No aftermarket add ons for my build but original harnesses are not in great shape so now's the time to avoid these problems down the road.
Re: Aftermarket wiring kits [Re: busboy] #2389551
10/18/17 10:05 PM
10/18/17 10:05 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I installed a Painless and it's sufficient. I ended up significantly modifying it for my car however, a whole new fuse box.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Aftermarket wiring kits [Re: GoodysGotaCuda] #2404066
11/15/17 05:48 PM
11/15/17 05:48 PM
busboy Offline OP
busboy  Offline OP
Orders in, should be here next week, be going in over the winter so I'll update on the install. Thanks for the help up
Re: Aftermarket wiring kits [Re: busboy] #2404078
11/15/17 06:05 PM
11/15/17 06:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Looking forward to your progress.
I plan on using the original fuse box and just using new wires.
I have mechanical Aptitude.
I can screw up anything.
Re: Aftermarket wiring kits [Re: moparx] #2404115
11/15/17 06:54 PM
11/15/17 06:54 PM
which one or ones would you recommend?
Re: Aftermarket wiring kits [Re: bboogieart] #2404117
11/15/17 06:58 PM
11/15/17 06:58 PM
that's what I did on a 65 dart & it was ALOT of work (& this was a bare bones vehicle). I set the harnesses on the floor & made up the new one next to it & added one wire in the new one & cut the old wire out of the old one till the new one took shape & the old one dissappeared. I used larger wires on some circuits & it is critical to use the same colors/colors with tracers as the original ones & there are companies that will sell you any length of any gauge wire of any color or color with tracer.
Re: Aftermarket wiring kits [Re: moparx] #2404121
11/15/17 07:02 PM
11/15/17 07:02 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I have never had an issue with my "cheapo" crimping tool.
The secret is to make a proper crimp.
Size it properly.
Put the split in the connector in the round side and force the raised punch side into the solid part of the connector.
Can't pull it out of the connector.
Just my experience. shruggy
Re: Aftermarket wiring kits [Re: busboy] #2404214
11/15/17 09:46 PM
11/15/17 09:46 PM
WV
JohnH Offline
JohnH  Offline
WV
I bought the original wiring harness from Year One,, I got the complete kit front to rear with a 30% one day discount... very nice,,
Re: Aftermarket wiring kits [Re: bboogieart] #2404225
11/15/17 10:01 PM
11/15/17 10:01 PM
Size it properly.
Noted
Re: Aftermarket wiring kits [Re: RapidRobert] #2404920
11/17/17 12:48 PM
11/17/17 12:48 PM
moparx Offline
moparx  Offline
double R, i have quite a few, depending on the job at hand, and the type of connection required. i have a klein, and a bluepoint lineman's pliers, sever types of AMP ratcheting crimpers, crimpers for insulated and non insulated terminals, crimpers for molex, deuche [not sure of this spelling], weatherpack, and a cool hydraulic heavy cable crimper i stumbled into while searching for something else, that does from 8ga. to 00battery cable. that tool was only $20, and is an import, but works fantastic ! some tools crimp both the connector and insulation at the same time, while with some, you need to do each separately. i also have a couple of plug wire terminal crimpers. for strippers, i have several "squeeze" the handles together types that automatically strip the insulation [my snapon tool being the one i use the most] as well as the more common types you see where you place the tool on the insulation, then pull the wire. other tools i consider "musts" for wiring are the tools used to remove terminals from main connectors, of which there are several, as well as eyeglass screw drivers, picks, and many items i have made for odd jobs over the years. and the BEST advice i can give on wiring is : "practice with your tools using quality terminals and scrap wire." the terminals will be sacrificial, but doing this will show you how your tools work [and there are differences between different brands of the same tools], and allow you to polish a technique that works the best for you. don't know if this answered your question or not.
beer
Re: Aftermarket wiring kits [Re: moparx] #2404996
11/17/17 02:45 PM
11/17/17 02:45 PM
but doing this will show you how your tools work and there are differences between different brands of the same tools, and allow you to polish a technique that works the best for you. don't know if this answered your question or not.
it certainly did , thank you. I've heard of those that pull the insulation all in one motion & if I was doing alot of this I would spring for one of those types. & I'm a believer in good soldering.
Re: Aftermarket wiring kits [Re: busboy] #2409012
11/26/17 05:03 AM
11/26/17 05:03 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I installed an American Autowire HWY 15 kit. It's quality stuff for sure. Their tech support is absolutely outstanding. The kit you are buying has all the subharnessess with it. I had to build all of mine. I would do it again. It's pretty stupid to spend a boatload of money on 50 year old technology if you don't care about stock appearance.
I’m listening.
