Re: Push rod length 383
[Re: moparphilll]
#2388063
10/16/17 10:52 AM
10/16/17 10:52 AM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Pretty sure 66 had smaller pushrod tips. You need to match the pushrods to the lifters that you are using. I think 68 was the first year for the larger size but I could be wrong on the years. All the lifters you buy today have the larger 5/16" ball end.
[Re: markz528]
#2388317
10/16/17 07:31 PM
10/16/17 07:31 PM
dogdays
Rockers are the same, pushrods different. Here's the pushrods from Rockauto: http://www.rockauto.com/en/moreinfo.php?pk=216005&cc=1435009&jsn=472It's really too bad because,if you decide later to change out the camshaft, you're probably going to get the later model lifters and have to buy pushrods again. R.
[Re: dogdays]
#2388650
10/17/17 11:18 AM
10/17/17 11:18 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
No need to change the pushrods. The smaller ball will work in the larger cup, remember it has to fit the cup in the lifter AND the cup in the rocker. Later pushrods will not work in the earlier lifters/rockers. However, this being a rebuild and you not having rockers already, I would put the later stuff in. the factory upsized the pushrods for a reason, same with the later HD rockers. Since you probably replaced the cam in the rebuild you should already have the later lifters.
[Re: moparphilll]
#2388671
10/17/17 11:49 AM
10/17/17 11:49 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
ooh, ok so te "problem" would be the pushrod diameter but not the lenght... right ?
never advertised that before!
[Re: NachoRT74]
#2388690
10/17/17 12:35 PM
10/17/17 12:35 PM
RapidRobert
never advertised that before! Actually it is common knowledge, Nacho You are probably spending too much time watching hand egg instead of being on here like you should be.
[Re: RapidRobert]
#2388821
10/17/17 04:30 PM
10/17/17 04:30 PM
NachoRT74
Valencia, España
never advertised that before! Actually it is common knowledge, Nacho You are probably spending too much time watching hand egg instead of being on here like you should be. LOL
[Re: moparphilll]
#2388847
10/17/17 05:12 PM
10/17/17 05:12 PM
Posts: 59 Florida
Sweet5ltr
Honest reply,
Purchase a $10 adjustable pushrod and obtain the correct length.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: Sweet5ltr]
#2389369
10/18/17 04:10 PM
10/18/17 04:10 PM
dogdays
The pushrod diameter is the same. The end of the pushrod that contacts with the rocker is the same. It's the diameter of the cup in the lifter, plus the lifter end of the pushrod, that are different. The earlier pushrod has a clearly visible necked down portion that fits into the smaller cup on top of the lifter. They ARE different lengths. Overall length of the early one is 8.645", while the later model pushrod is 8.575" Pictures is late pushrod. Find a picture of the earlier pushrod end here: http://www.rockauto.com/en/moreinfo.php?pk=216005&cc=1435010&jsn=493R.
[Re: dogdays]
#2389499
10/18/17 08:44 PM
10/18/17 08:44 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
The pushrod diameter is the same. The end of the pushrod that contacts with the rocker is the same. It's the diameter of the cup in the lifter, plus the lifter end of the pushrod, that are different. The earlier pushrod has a clearly visible necked down portion that fits into the smaller cup on top of the lifter. They ARE different lengths. Overall length of the early one is 8.645", while the later model pushrod is 8.575" Pictures is late pushrod. Find a picture of the earlier pushrod end here: http://www.rockauto.com/en/moreinfo.php?pk=216005&cc=1435010&jsn=493R. All the early, pre 1968 or 1967, had the 1/4 inch ball pushrod ends for those lifters that where different lengths. I wouldn't bet money that Mopar went to the later lifter cup and same size pushrods on both ends so some of the dealer wrenches wouldn't install them upside down and pierce the rocker arms under warrenty I did that on a 1965 413 I put together for my wife 1965 Dodge Coronet 500, install one side correctly and did the opposite on the other side, I ended up punching through three rockers arms going up the old highway from Mesquite AZ to St George, UT back in the early 1970s Luckily the local dodge dealer had them in stock and some new lifters for that year also The retaining clips in the lifters had got knock out of two of them and ended up washing down into the oil pan, a good stick magnet got those two lifters out and really help installing the new ones
