Slick air pressure
#2387962
10/16/17 12:50 AM
10/16/17 12:50 AM
Posts: 252 southeast ky
mills.mopar
southeast ky
No doubt this is a dumb question... But how do you know if you have the correct air pressure in your slicks. I've got 28x10 Hoosier now. I've been running 14.5 psi. My wife came to the track and took some pretty good pictures last night, seems like they might be rolling up a bit to much on launch. I wish I could describe it, or better yet post a picture.... But I can't. Anyway if y'all can help I'd appreciate it. I made it to six cars last night and four the weekend before. I'd like to be able to seal the deal before the end of season. Btw. Car runs 7.20 1/8 mile. 1.58 60ft. 68 dart. Weight unknown.
Jeff.
If you love it lube it
68 dart 37 dodge coupe 71 challenger
Re: Slick air pressure
[Re: mills.mopar]
#2387974
10/16/17 01:18 AM
10/16/17 01:18 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Yep. What Cab said. Also, do you run tubes? I do and my setup likes more air than without. Weight of car is also big factor of how much pressure. Try to weigh it next track day
[Re: mills.mopar]
#2388017
10/16/17 03:58 AM
10/16/17 03:58 AM
Posts: 5,894 Florida
Locomotion
As described above...but basically, as much air as possible while maintaining a full-width footprint. Too much "wrinkle" isn't good for sidewall life and the "wrinkle" can extend to the tread. But the wider the rim, the more air you can usually run. Stock class cars that are limited to 9" slicks usually run 10" rims. I run around 20-21 in Hoosier radial slicks, weighing 3,540+, footbraking, usually around 1.49 - 1.50 with 7-teens. Radial slicks are a bit faster and take a bit more air than bias ply slicks, but not as consistent on marginal tracks.
Shocks/suspension could be hitting the rear a bit too hard as well. But if you're consistent & going rounds, that can't be too far off.
It would only be a "rough" indicator because it probably wouldn't be hooking and transferring weight like on a prepped track, but launching on clean pavement, set up like at the track, can help show your footprint and possibly go up a bit with pressure from there, if needed.
[Re: mills.mopar]
#2388030
10/16/17 08:56 AM
10/16/17 08:56 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I think you are pretty close. You can go up in 1/2 lb increments until you slow down, as said earlier, then drop back down 1/2 lb. My car is light, with a big tire. I start slightly high on pressure, and work my way down until the car gets a little sloppy on the top end, then go back up 1/2 lb.
[image][/image]
[Re: sgcuda]
#2388210
10/16/17 03:34 PM
10/16/17 03:34 PM
mills.mopar
southeast ky
Thanks much folks.
I don't run tubes. We unfortunately don't have scales at the track. I've been thinking about taking it to the truck stop to get a rough idea what it weighs. I don't know of any other scales around here.
It's a foot break car on super stock springs.
[Re: mills.mopar]
#2388360
10/16/17 08:36 PM
10/16/17 08:36 PM
Posts: 43,254 Bend,OR USA
Cab_Burge
