New engine "overheated", potential problems?
#2387520
10/14/17 10:57 PM
10/14/17 10:57 PM
Posts: 370 Suffolk County, New York
1mean340
Ugh, This thing has been plagued by bad luck lol. Took out the supercharged/e85 340 for a ride to work on tuning and trouble shoot a few ignition problems. I let it warm up for maybe 5 minutes, checked trans fluid and began taking it around the block when I realized it was creeping up to 220degrees. I was just turning onto a main road so I figured I'd give it some speed and let the air cool it but it started climbing slowly. I turned around to head home and just as I started pulling down my street the temp started climbing quickly to 240. by the time I shut it down I was at around 250 and coasted it into my driveway. No engine noise, but I had some water spraying out of my hose clamps and the radiator was making a A few loud bangs after I shut down.
Turns out the brand new thermostat I had in there stuck itself closed.
I'm just really worried about the motor being it is brand new, only has maybe 50 miles on it and I'm still running break in oil. I mean it only ran at 240/50 for a few seconds at most, should I be worried? I wish I could have shut it down sooner but the street was busy with traffic coming up behind me and I didn't feel safe getting stuck on the main road when my driveway was just a few yards ahead.
Re: New engine "overheated", potential problems?
[Re: 1mean340]
#2387524
10/14/17 11:06 PM
10/14/17 11:06 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
I've had stuff that hot before and it never hurt it. Scares ya a lil tho. My overheating adventures happened with stock stuff.
[Re: 1mean340]
#2387647
10/15/17 10:59 AM
10/15/17 10:59 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
You should be fine, I forgot to plug my water pump back in once and didn't realize until I was sitting first in line in the left hand turn lane at the busiest intersection in town. It was off the temp gauge by the time my light turned green and I was able to pull over and plug it in. I was more worried about cooling it down to fast than I was the actual temp. No issues and it lived on for several more years before I pulled it for another engine.
68 Barracuda Formula S 340
[Re: 1mean340]
#2387798
10/15/17 05:39 PM
10/15/17 05:39 PM
Posts: 4,209 New York
polyspheric
New York
The temperature you saw on the gauge is not the highest temperature in the engine, which was probably in the spark plug and exhaust seat cooling loops. At those locations your safety is the cap pressure which prevents local boiling.
Boffin Emeritus
[Re: 1mean340]
#2388076
10/16/17 11:40 AM
10/16/17 11:40 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I wouldn't worry about it at all. I've had em that hot before w/ no problems.
