1974 charger rear leaf spring isolators #2387464
10/14/17 07:58 PM
10/14/17 07:58 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
is there a kit to eliminate the isolators ? or can you just cut them off and weld on new pads ?
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 1974 charger rear leaf spring isolators [Re: sparcy] #2387650
10/15/17 11:11 AM
10/15/17 11:11 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
there is a kit. firmfeel sells it.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 1974 charger rear leaf spring isolators [Re: sparcy] #2387657
10/15/17 11:28 AM
10/15/17 11:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Or simply get 71/72 lower/shock plates ( probably earliers work too??? ) fill the axle pedestal hole with a washer and remove the springs "hat" bushings from guide studs.
Maybe will need shorter U bolts too.
Re: 1974 charger rear leaf spring isolators [Re: sparcy] #2387663
10/15/17 11:33 AM
10/15/17 11:33 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
FWIW - You can also get poly bushings from PST.
Common sense is a flower that does not grow in everybody's garden
Re: 1974 charger rear leaf spring isolators [Re: sparcy] #2387675
10/15/17 11:54 AM
10/15/17 11:54 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think he meant the spring pads used on 73 and lates assemblies. Which BTW are also available on poly.
Re: 1974 charger rear leaf spring isolators [Re: NachoRT74] #2387830
10/15/17 07:20 PM
10/15/17 07:20 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
'73 used idolators too.
John
Re: 1974 charger rear leaf spring isolators [Re: Jerry] #2387847
10/15/17 08:20 PM
10/15/17 08:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Kinda pricey though.
http://www.firmfeel.com/b_body_late_mopar_iso_delete_kit.html
