Tire Spinning On Rim?
#2387351
10/14/17 02:34 PM
10/14/17 02:34 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Twice this year, I have had to remove the beauty ring and re-center the air valve in the center of the hole. I tried rotating the ring by hand and it will not rotate. Does this mean that the tire is rotating on the wheel? This is a new 15x8 wheel with Nitto 275 on the rear. The air pressure was 24psi both times it has happened. I am now trying 28psi.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Tire Spinning On Rim?
[Re: B5 Bee]
#2387379
10/14/17 04:04 PM
10/14/17 04:04 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The trim ring moved. Even if the tire slipped it will not move the valve stem unless you are running tubes. Yep.
[Re: B5 Bee]
#2387380
10/14/17 04:05 PM
10/14/17 04:05 PM
YO7_A66
Indiana
No tubes. 24psi made for full foot print. Thanks
[Re: YO7_A66]
#2387421
10/14/17 05:48 PM
10/14/17 05:48 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I say trimring moved. Did this happen during driving or dragrace? After this launch my tires had rotated considerably on the wheels.
[Re: AARCONV]
#2387457
10/14/17 07:33 PM
10/14/17 07:33 PM
YO7_A66
Indiana
Spirited driving on street. I will pull that trim ring back off and bend the tangs to see if that helps.
Thanks to all!!
[Re: BigBlockMopar]
#2387510
10/14/17 10:43 PM
10/14/17 10:43 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I agree. By the way Big Block, That is some MONSTER torque. Nice looking Hot Rod too.
I have mechanical Aptitude. I can screw up anything.
[Re: BigBlockMopar]
#2387868
10/15/17 09:24 PM
10/15/17 09:24 PM
YO7_A66
Indiana
I pulled the ring today and bent out a lot of the tangs. Some of them were pushed inward and may not have been doing much. I will test this and keep an eye on it. thank you
