Re: Trick Flow vs Indy
[Re: DusterKid]
#2387240
10/14/17 09:39 AM
10/14/17 09:39 AM
Posts: 9,997 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Your original post stated a number of critical issues that will limit horsepower. Combined, they will take away a BUNCH of horsepower. I don't see those issues being factored in to the suggestions given in your first post. That is why I firmly believe you need all the cubes you can build into this motor, plus large port heads, and don't be afraid of a few more rpm. You need to rev to 6600 to 6800 to make your goal, which is equivalent to 9.70 to 9.99 IN GOOD AIR. My first low deck combo on gas Made enough power to run 9.50s, at 3000 pounds race weight. But I had these advantages. I was 200 pounds lighter, which is at least .2 seconds et, 12.9 compression, another .1, and a roller cam, another .10 to .15, and large port heads. On top of that I was shifting at 6800 because the cam was 283 intake at .050 and .750 lift, with 290 duration and .681 on the exhaust. In short, build what you think is about 75 hp llong for your goal, and if your whole combo is fairly good, you will achieve it. While that combo I discribed might have had more in it, it was easily repeatable, not a build that used a number of tricks to build the most hp it could. It is tough to make serious hp, so be very conservative on the estimate of what you chose to build.
[Re: bonefish]
#2387414
10/14/17 05:04 PM
10/14/17 05:04 PM
Posts: 72 WI
Brewzer67
WI
i can only speak on the sr,s. i had a set of unported sr heads prepped by Dwayne Porter in a 496 combo with a Dwayne spect cam and it ran AWSOME,10:50,s in a 4,129 lb car on pump gas. Any chance you could share specifics of the build (head flow, cam, etc.)?
[Re: Brewzer67]
#2387436
10/14/17 06:42 PM
10/14/17 06:42 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i can only speak on the sr,s. i had a set of unported sr heads prepped by Dwayne Porter in a 496 combo with a Dwayne spect cam and it ran AWSOME,10:50,s in a 4,129 lb car on pump gas. Any chance you could share specifics of the build (head flow, cam, etc.)? i,ll have to look it all up but i might be able to find it.this was quit a few years ago.
[Re: gregsdart]
#2387542
10/14/17 11:38 PM
10/14/17 11:38 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
Your original post stated a number of critical issues that will limit horsepower. Combined, they will take away a BUNCH of horsepower. I don't see those issues being factored in to the suggestions given in your first post. That is why I firmly believe you need all the cubes you can build into this motor, plus large port heads, and don't be afraid of a few more rpm. You need to rev to 6600 to 6800 to make your goal, which is equivalent to 9.70 to 9.99 IN GOOD AIR. My first low deck combo on gas Made enough power to run 9.50s, at 3000 pounds race weight. But I had these advantages. I was 200 pounds lighter, which is at least .2 seconds et, 12.9 compression, another .1, and a roller cam, another .10 to .15, and large port heads. On top of that I was shifting at 6800 because the cam was 283 intake at .050 and .750 lift, with 290 duration and .681 on the exhaust. In short, build what you think is about 75 hp llong for your goal, and if your whole combo is fairly good, you will achieve it. While that combo I described might have had more in it, it was easily repeatable, not a build that used a number of tricks to build the most hp it could. It is tough to make serious hp, so be very conservative on the estimate of what you chose to build. Definitely, weight is a big issue...I have been running a 512 RB for 7 years. Best ET 6.13 and 9.70 on pump gas.....But at 2770lbs. Roller .680 cam with 10.8:1. I run the EZ-1 heads, and they have been awesome. At your weight, you will want better heads yet. I have just switched to a 400/512 all the rest the same except light weight crank...Had an issue that has been holding it back. Gone 6.25 so far.
[Re: Dragula]
#2387668
10/15/17 11:38 AM
10/15/17 11:38 AM
Posts: 1,030 ohio
67mprfan
ohio
I have just switched to a 400/512 all the rest the same except light weight crank...Had an issue that has been holding it back. Gone 6.25 so far. [/quote]
Do you mind sharing what the issue was
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
