Re: 69 b body ignition switch replacement fit
[Re: moparpro]
#2386858
10/13/17 01:56 PM
10/13/17 01:56 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I guess he meant about the bezel nut and dash frame, not really the diameter, thinking on shim the assembly to get it tight to the dash frame
[Re: moparpro]
#2387089
10/13/17 10:06 PM
10/13/17 10:06 PM
Posts: 3,380 KY USA
mopargem
KY USA
Maybe you could find something in the plumbing section or a nylon washer for a utility wheel or an O ring or something of that nature ?? Depot had those bin trays with sort of odd spacers etc
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: moparpro]
#2387230
10/14/17 08:53 AM
10/14/17 08:53 AM
Posts: 1,565 tennessee
pushbutton
tennessee
yes nacho, that is what i mean,what is good for shims,i want thin washer but i can not find some with hole big enough fit around switch. Find a washer with the correct outside diameter and enlarge the hole with a round file or a rotary file in a drill or die grinder.
[Re: moparpro]
#2387273
10/14/17 11:37 AM
10/14/17 11:37 AM
NachoRT74
Valencia, España
I'm agreed one the pluming nylon washers or an O ring... they will mold to the diameter and thickness easier without overthink the needed size
