69 b body ignition switch replacement fit #2386584
10/12/17 11:06 PM
10/12/17 11:06 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
has anyone bought one recently to find out at least in my case it does not fit into dash hole tight enough and has some movement with it even you tighten it real good,any ideas on how to stabilize it better?i thought two thin washers would do the trick but i have not found any with large enough holes to fit switch. thanks
Re: 69 b body ignition switch replacement fit [Re: moparpro] #2386690
10/13/17 06:37 AM
10/13/17 06:37 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
69 uses a one year only diameter switch.
You probably have the 68 and older size switch.
The hole in the dash is much larger in 69 ... I believe I seen someone making an adapter to allow use of the common size in the larger hole.
Otherwise true 69 switches are pricey.
Re: 69 b body ignition switch replacement fit [Re: moparpro] #2386858
10/13/17 01:56 PM
10/13/17 01:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I guess he meant about the bezel nut and dash frame, not really the diameter, thinking on shim the assembly to get it tight to the dash frame
Re: 69 b body ignition switch replacement fit [Re: NachoRT74] #2387074
10/13/17 09:40 PM
10/13/17 09:40 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
yes nacho, that is what i mean,what is good for shims,i want thin washer but i can not find some with hole big enough fit around switch.
Re: 69 b body ignition switch replacement fit [Re: moparpro] #2387089
10/13/17 10:06 PM
10/13/17 10:06 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Maybe you could find something in the plumbing section or a nylon washer for a utility wheel or an O ring or something of that nature ?? Depot had those bin trays with sort of odd spacers etc
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 69 b body ignition switch replacement fit [Re: moparpro] #2387230
10/14/17 08:53 AM
10/14/17 08:53 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Find a washer with the correct outside diameter and enlarge the hole with a round file or a rotary file in a drill or die grinder.
Re: 69 b body ignition switch replacement fit [Re: moparpro] #2387273
10/14/17 11:37 AM
10/14/17 11:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm agreed one the pluming nylon washers or an O ring... they will mold to the diameter and thickness easier without overthink the needed size
