I think theres a problem with my Cal-trac monos #238717
02/28/09 12:23 PM
02/28/09 12:23 PM
Somewhere Over the Hill
Mr. Dodge Offline OP
I pulled the car out of the garage yesterday and the drivers side of the car is drooping about +/- 1.5 inches. Its a very noticeable droop. Is that normal. Its reminding me of the SS spring droop on one side.
Do you have any pics of your car from behind....Maybe its supposta be that way????
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238718
02/28/09 12:39 PM
02/28/09 12:39 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
i would call calwert and ask, from what i have read is very good at answering stuff..
could it be that you have just had real uneven worn springs in the past and the whole car has been adjusted that way with the torsion bars?
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238719
02/28/09 12:50 PM
02/28/09 12:50 PM
measure your bottom of front fender to the floor and get measurements from both sides, then adjust your torsion bar accordingly to get the proper ride height.
for your cal tracs to work properly you need to get 5" of front end travel.
you dont need to call calvert
your next question is how do i figure out how to achieve 5" of front end travel.
Re: I think theres a problem with my Cal-trac monos #238720
02/28/09 01:47 PM
02/28/09 01:47 PM
I'll check out my T-bar settings when I get a chance.....
Ya How do ya get 5" of travel I have /6 t-bars and I'm gonna get Cal-tacs 90/10 front shocks what else should I do????
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238721
02/28/09 01:49 PM
02/28/09 01:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cut the upper controll arm rubber stops to achieve the desired travel. Mine are a bit over a 1/4" and have 5+"`s of travel.
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238722
02/28/09 02:40 PM
02/28/09 02:40 PM
Connecticut
5126brl No more Offline
Connecticut
If you just put them in and had Super Stock springs before You need to re adjust T-bars.
with the ss springs you had a ton of pre load in the left side to level car.
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238723
02/28/09 03:04 PM
02/28/09 03:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had the same problem with mine 3 years ago and I had heard that Calvert had a "bad batch" of springs I could clearly see the arch was completely gone and the springs went flat.I sold them and went back to SS springs and later found out that Calvert would have replaced them.I would call them and ask them what they can do about it.
Gus
64 Plymouth Savoy
Dana 60
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238724
02/28/09 03:17 PM
02/28/09 03:17 PM
GET your desired right height which probably will be different when finding 5" of travel.
1st set ride height with car level and take the measurement from bottom of fender to center of the wheel.
2nd jack up front of the car on k member until front wheels are off the ground then take the same measurement with wheels off the ground.
the difference of the measurement of the 2 should be 5".
3rd if its less than 5" lower the torsion bar or remove the rubber stop bumper to achieve maximum travel
Re: I think theres a problem with my Cal-trac monos #238725
02/28/09 05:12 PM
02/28/09 05:12 PM
UK
602heavy Offline
602heavy  Offline
UK
Had a similar problem whereby the drivers side was around 1" lower than pas side , found it was the pin that loads the caltrac had fallen out , was the snap ring that went AWOL , hence the bar slipped out , the fix was to use a nut & bolt to hold the pin.
Re: I think theres a problem with my Cal-trac monos [Re: Mr. Dodge] #238726
03/01/09 10:19 AM
03/01/09 10:19 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Just remember, any time you change the torsion bar settings you MUST get the car realigned.
