W2 Head ID #238713
02/28/09 12:16 PM
02/28/09 12:16 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Had this posted in the Q/A section it was suggested to try here also. I have a set of closed chamber W2 heads that have P4532693 cast into them which seems to cover a few different versions. Can anyone help identify exactly which head it is? A google search came up with them being...
P4532693 = P5249769
59 degree tappet
65 CC closed chamber
18 degree valve angle
Anyone confirm or deny this info? They have the dual bolt pattern on the exhaust side if that helps.
1972 Road Runner
1988 Shelby CSX-T
Re: W2 Head ID [Re: racerx20] #238714
02/28/09 12:34 PM
02/28/09 12:34 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It's definitely a 59º head and the P4532693 casting was used
for heads with different part numbers.(W-2) Checking the chamber
volume is the only way I could tell. I'm not sure if the 65cc head
had a different chamber shape or not. Here's a 55cc W-2 with the
same casting number. I'm sure, it's either the 55cc or 65cc verision.
Re: W2 Head ID [Re: S/ST 3040] #238715
02/28/09 02:02 PM
02/28/09 02:02 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Thanks for the info I am going to CC them to see for sure.
1972 Road Runner
1988 Shelby CSX-T
Re: W2 Head ID [Re: racerx20] #238716
02/28/09 02:56 PM
02/28/09 02:56 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Those look like the 55cc version.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
