340 oil filter base, adding holes for flow
#2386190
10/12/17 11:18 AM
10/12/17 11:18 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I have a '71 340 that had the 90° adapter oil filter on it. I am swapping it for a standard base so the filter screws right onto the side of the block. The only one I have is off of a '69 318...see pic.
Is there anything wrong w/ drilling the extra 4 holes in this one like the 340/360 plates have? Instead of buying another one.
Re: 340 oil filter base, adding holes for flow
[Re: an8sec70cuda]
#2386197
10/12/17 11:30 AM
10/12/17 11:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had a old plate that I put 8 holes in.. worked out great.. the other plates that I had already had 8 holes
[Re: an8sec70cuda]
#2386339
10/12/17 03:45 PM
10/12/17 03:45 PM
an8sec70cuda
[Re: an8sec70cuda]
#2386378
10/12/17 05:04 PM
10/12/17 05:04 PM
an8sec70cuda
EV2...no, I'm getting rid of the 90° adapter.
[Re: an8sec70cuda]
#2386382
10/12/17 05:09 PM
10/12/17 05:09 PM
an8sec70cuda
All I've heard is how the 90° adapters are leak prone and I don't need one anyway w/ the factory '71 manifolds.
[Re: an8sec70cuda]
#2386387
10/12/17 05:29 PM
10/12/17 05:29 PM
an8sec70cuda
Yes, that's what I'm looking to make. I don't have much small block stuff and the only adapter plate I have here is off a 318...which only has 4 holes.
[Re: an8sec70cuda]
#2386391
10/12/17 05:47 PM
10/12/17 05:47 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have done the same as well, I even drilled the square hole out of the middle of the hold down. I used one of the fancy Canton plates on the current motor though.
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#2386433
10/12/17 06:55 PM
10/12/17 06:55 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Maybe I'm thinking wrong but compare the combined surface area of the four holes in the plate to the surface area of the hole in the block. The block is the restriction.
[Re: an8sec70cuda]
#2386547
10/12/17 10:13 PM
10/12/17 10:13 PM
Posts: 4,206 New York
polyspheric
New York
The abrupt size change of the filter holes is a "vena contracta", or restriction far worse than the actual size suggests. By comparison, a long shallow taper leading to and from the same size hole flows much better - but no way to do that. I blend and radius every oil passage I can reach.
Boffin Emeritus
[Re: polyspheric]
#2386638
10/13/17 12:50 AM
10/13/17 12:50 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
a long shallow taper leading to and from the same size hole flows much better - Isn't that called a "Venturi" Which enhances flow, correct
[Re: MR_P_BODY]
#2386823
10/13/17 12:57 PM
10/13/17 12:57 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I had a old plate that I put 8 holes in.. worked out great.. the other plates that I had already had 8 holes Same here............
