I have been told that anything above 1.50 diameter spring wont work with these rocker arms.
Maybe you shouldn't believe everything you're told. A stock big block spring is 1.55" diameter. Do you think HS would make a rocker that couldn't be used with a stock spring? I have HS rockers, 1.55" dia. springs and no issues at all with clearance. And yes, its a solid roller cam but that makes no difference.
He's running a small block with rpm heads.
That combo has pretty limited space between the rocker and the spring, and HS rockers rub 1.55 springs on those heads.
It's right on the HS website, 1.50 max spring diameter.
Oh, and I'm pretty sure OE BB springs are slightly under 1.500(1.48-1.49 IIRC) not 1.550.
