Re: Small diameter roller cam springs [Re: B3422W5] #2386177
10/12/17 10:51 AM
10/12/17 10:51 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I have been told that anything above 1.50 diameter spring wont work with these rocker arms.
Maybe you shouldn't believe everything you're told. A stock big block spring is 1.55" diameter. Do you think HS would make a rocker that couldn't be used with a stock spring? I have HS rockers, 1.55" dia. springs and no issues at all with clearance. And yes, its a solid roller cam but that makes no difference.
He's running a small block with rpm heads.
That combo has pretty limited space between the rocker and the spring, and HS rockers rub 1.55 springs on those heads.
It's right on the HS website, 1.50 max spring diameter.
Oh, and I'm pretty sure OE BB springs are slightly under 1.500(1.48-1.49 IIRC) not 1.550.
After posting it occurred to me that he probably had a small block. I thought I had deleted my post but obviously not.
Re: Small diameter roller cam springs [Re: B3422W5] #2386290
10/12/17 02:26 PM
10/12/17 02:26 PM
Locomotion Offline
Locomotion  Offline
See if any of the stiffer beehive springs from Comp Cams or PAC fit the required specs. As with all springs, check pressures periodically.
I don't like cutting rockers for clearance because I've seen too many break there.
Re: Small diameter roller cam springs [Re: B3422W5] #2386314
10/12/17 02:59 PM
10/12/17 02:59 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
With that particular head/rocker combo, rather than trying to reinvent the wheel, I just use cam lobes that will work with springs that fit those heads & rockers.
From what I understand, the T&D's will clear the 1.55 springs.
With a little spring pocket cutting and tall retainers, you can get 1.900 installed height....... So, that combined with the T&D's opens up the spring selection quite a bit.
However, you're still dealing with 5/16" hold down hardware.
Re: Small diameter roller cam springs [Re: B3422W5] #2386319
10/12/17 03:05 PM
10/12/17 03:05 PM
I have used either Comp or PAC for a blown SB Chevy years ago that where 1.440 O.D., I don't remember the exact installed and open pressures but I'm sure they where above 225 Lbs. on the seats and over 500 lb. opened scope
I think they where dual spring with a dampener.
