Fuel Cell, foam or no foam? #2385752
10/11/17 05:28 PM
10/11/17 05:28 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
I picked up a 64 dart I'm going to be setting up for some bracket racing. Since I have to replace the gas tank I figured I just go to a fuel cell, about the same price and already has a sump. Do I go with a cell with or without foam? please give me your guy's input, advantages/disadvantages.
I know the foam is supose to help with sloshing but have heard that it deterioates over time causing clogs and will need to be replace.
This is basiclly a strip car with a bit of steet use.
Thanks,
Gary
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2385761
10/11/17 05:38 PM
10/11/17 05:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Have had foam in mine forever and see very little in the filter plus helps w/slosh........... thumbs
Re: Fuel Cell, foam or no foam? [Re: Thumperdart] #2385787
10/11/17 06:12 PM
10/11/17 06:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran the foam in mine even with E-85.. had
in there for about 10 years.. a cheap cell
will have cheap foam in it and will break
down after time.. if you dont run the foam
I would at least look into some baffles to
slow or stop the slosh.. and the slosh can
be noisey.. I did a lot of noise work back
at Chrysler to make tanks quiet
wave
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2385799
10/11/17 06:28 PM
10/11/17 06:28 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I've been researching this topic also and there are so many varying opinions about the foam. Some say no problem others say its the worst thing to do, maybe as said above it depends on the quality of the cell/foam.
My plan it to go no foam or remove the foam from the cell and run an efi in-tank pump to a carb using a bypass regulator. I'm also planning on using this deal from tanksinc to provide a baffle system for hard acceleration:
http://www.tanksinc.com/index.cfm/page/p...=prod/prd84.htm
Anybody else doing this? I'd love some feedback if this is a good/bad idea. Not to hijack but thought the OP might be interested also.
thanks,
Steve
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2385801
10/11/17 06:34 PM
10/11/17 06:34 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
I have had two fuel cells with foam in them. One is still going strong after many many years. The other broke down in about 3-4 years and clogged filters etc. If I were going to put in a new cell, I would not worry about it. If the cell is old, I would watch it closely. To be safe I always put my filter on the output of the cell and before the fuel pump to keep it out of my carbs should the foam break down.
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2385812
10/11/17 06:56 PM
10/11/17 06:56 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mine has had foam for 5 years, no breakdown. Never found any foam in the filter.
Doug
Re: Fuel Cell, foam or no foam? [Re: dvw] #2385821
10/11/17 07:19 PM
10/11/17 07:19 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
Jim, I bought mine new in 1975, has foam in it. Never broke down, still using it. Just get one. It will live longer than we do.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Fuel Cell, foam or no foam? [Re: Steve1118] #2385860
10/11/17 08:20 PM
10/11/17 08:20 PM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Didn't think about the noise from sloshing up
and thanks for the link to tanksinc, some good info there.
Sounds like foam with a good filter is the way to go. oh and it will be a new cell so no issues there.
Thanks for the feedback.
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2385889
10/11/17 09:15 PM
10/11/17 09:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks,
Gary
Per Magnafuel, no foam.
Fastest 300
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386051
10/12/17 01:33 AM
10/12/17 01:33 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
What I learned was the foam should be removed for methanol. Most racing fuels won’t bother it. I’m not sure about Q-16. I run methanol in 2 cars and have removed the foam from both.
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386187
10/12/17 11:08 AM
10/12/17 11:08 AM
an8sec70cuda Offline
Had a cell w/ foam in the Camaro (5 sec 1/8 mile, SBC N/A, drag only), but it started breaking down after a couple years. Removed it at that time and been that way ever since w/ no trouble.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386247
10/12/17 12:58 PM
10/12/17 12:58 PM
Superfreak
Superfreak
I have a 20gal aluminum fuel cell with the foam and now thinking about it, it would only hold about what? 5gals of fuel.
Re: Fuel Cell, foam or no foam? [Re: ] #2386468
10/12/17 07:50 PM
10/12/17 07:50 PM
dogdays Offline
dogdays  Offline
You might want to read up on the foam. Here's a fuel cell foam supplier who supplies to the US military. Their foam is 98% void, meaning you lose 2% of the volume to the foam.
Anyway this stuff looks like its cutting edge material.
http://www.ksrfoam.com/Fuel_Cell_Foam_Kits.php
R.
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386482
10/12/17 08:25 PM
10/12/17 08:25 PM
Superfreak
Superfreak
Thanks for the link, this cured my curiosity.
Re: Fuel Cell, foam or no foam? [Re: dvw] #2386603
10/12/17 11:40 PM
10/12/17 11:40 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
No FOAM....Been there, done that....No FOAM!
Re: Fuel Cell, foam or no foam? [Re: Crizila] #2386641
10/13/17 12:56 AM
10/13/17 12:56 AM
Az
Crizila Offline
Crizila  Offline
Az
Part of the problem with foam is you have no way of knowing how much fuel you have in the tank. No fuel gauge ( unless you go outside the tank with a clear tube ) and you can't visibly see the fuel level. So you use a stick to check the fuel level. Stick goes right in to the foam. Not good! You break the foam up just a little bit, and your dead meat.
Fastest 300
Re: Fuel Cell, foam or no foam? [Re: Crizila] #2386657
10/13/17 02:08 AM
10/13/17 02:08 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
10 years no problem with a summit brand cel, VP C-12, and E85.
I think its really hit and miss from what I have seen
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Fuel Cell, foam or no foam? [Re: Crizila] #2386710
10/13/17 09:41 AM
10/13/17 09:41 AM
Richmond Twp. Mi.
Mr340 Offline OP
Mr340  Offline OP
Richmond Twp. Mi.
Looking at the offerings on Summit's page they do show cells with foam and a sending unit.
https://www.summitracing.com/parts/jzp-251-116-01/overview/
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386790
10/13/17 12:12 PM
10/13/17 12:12 PM
Az
Crizila Offline
Crizila  Offline
Az
I stand rejected. bow
Fastest 300
Re: Fuel Cell, foam or no foam? [Re: Mr340] #2386793
10/13/17 12:15 PM
10/13/17 12:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
After being in 2 accidents and one big fire that burned me and the dragster to the ground I say use the foam. Much safer especially if your gonna drive it on the street where someone could rear end you and the cell is in your trunk.
