Re: saftey nuetral switch
[Re: marcjames]
#2386166
10/12/17 10:27 AM
10/12/17 10:27 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
pre 68s are just one wire since the back up light switch is on shifters up to 68. 69s was the first year for the 3 pins NSS with the back up light switch built in ( actually a mid year change )
[Re: marcjames]
#2386198
10/12/17 11:33 AM
10/12/17 11:33 AM
RapidRobert
I'm assuming your trans has the single pin NSS. Just run a wire from the "grn" terminal on the starter relay down to the NSS & you're set. if the trans has a 3 pin NSS, run the wire to the middle pin on it & you're set.
[Re: mikemee1331]
#2386447
10/12/17 07:20 PM
10/12/17 07:20 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Change to the 3-pin NSS was mid year 1968. (5/15/68 to be exact)
[Re: marcjames]
#2386530
10/12/17 09:51 PM
10/12/17 09:51 PM
NachoRT74
Valencia, España
yes sorry! forgot to post 68 mid year change!
[Re: John_Kunkel]
#2386562
10/12/17 10:30 PM
10/12/17 10:30 PM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
The change-over was apparently not immediate. My '68 bee was built in late June and has the one-wire switch.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
[Re: marcjames]
#2387437
10/14/17 06:54 PM
10/14/17 06:54 PM
RapidRobert
hey thanks everyone I ran a wire to the ground on relay works great thanks That was too easy!
[Re: 1KoolBee]
#2387456
10/14/17 07:32 PM
10/14/17 07:32 PM
John_Kunkel
Rio Linda, CA
The change-over was apparently not immediate. My '68 bee was built in late June and has the one-wire switch. What's the build date on the trans?
