saftey nuetral switch #2386126
10/12/17 08:49 AM
10/12/17 08:49 AM
ny
marcjames Offline OP
ny
I have a 1967 gtx I would like to hook up my saftey neutral switch on the trans there is a single pole switch I have no wires I guess it goes to the starter relay ground where do I get the wire pigtail or can I just make my own is it just a single wire thanks mark
Re: saftey nuetral switch [Re: marcjames] #2386161
10/12/17 10:18 AM
10/12/17 10:18 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i just replaced the one on my 69 RR. mine was a 3 wire with both the switch and the pigtail available from NAPA. never heard of a 1 wire
Re: saftey nuetral switch [Re: marcjames] #2386166
10/12/17 10:27 AM
10/12/17 10:27 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
pre 68s are just one wire since the back up light switch is on shifters up to 68. 69s was the first year for the 3 pins NSS with the back up light switch built in ( actually a mid year change )
Re: saftey nuetral switch [Re: marcjames] #2386198
10/12/17 11:33 AM
10/12/17 11:33 AM
I'm assuming your trans has the single pin NSS. Just run a wire from the "grn" terminal on the starter relay down to the NSS & you're set. if the trans has a 3 pin NSS, run the wire to the middle pin on it & you're set.
Re: saftey nuetral switch [Re: NachoRT74] #2386208
10/12/17 12:04 PM
10/12/17 12:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
thanks Nacho, that's good to know wave
Re: saftey nuetral switch [Re: mikemee1331] #2386447
10/12/17 07:20 PM
10/12/17 07:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Change to the 3-pin NSS was mid year 1968. (5/15/68 to be exact)
Re: saftey nuetral switch [Re: marcjames] #2386530
10/12/17 09:51 PM
10/12/17 09:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes sorry! forgot to post 68 mid year change!
Re: saftey nuetral switch [Re: John_Kunkel] #2386562
10/12/17 10:30 PM
10/12/17 10:30 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
The change-over was apparently not immediate. My '68 bee was built in late June and has the one-wire switch.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: saftey nuetral switch [Re: marcjames] #2387398
10/14/17 04:39 PM
10/14/17 04:39 PM
ny
ny
hey thanks everyone I ran a wire to the ground on relay works great thanks
Re: saftey nuetral switch [Re: marcjames] #2387401
10/14/17 04:42 PM
10/14/17 04:42 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Cool! up
Re: saftey nuetral switch [Re: marcjames] #2387437
10/14/17 06:54 PM
10/14/17 06:54 PM
That was too easy!
Re: saftey nuetral switch [Re: 1KoolBee] #2387456
10/14/17 07:32 PM
10/14/17 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What's the build date on the trans?
