hello had a freind brought me a 300 that has been sitting for a while...carbs needed kits,gas tank wasnt to bad and didnt have very much so in it so filled tank added seafaom .rebuilt carbs replaced spark plugs and fuel filter,,,car starts right up,,but had a miss....started pulling wires,,,,clys 2468 do not make a difference,1357 do,,,getting good spark from cap to plugs,checked compression 150 on both sides,dist shaft has no play,replaced points(19thous)condenser, cap rotor,swapped wires, no change.also checked for intake leak none found..the exhaust manifold is cold on right side compared to left side..anyone run into this before..any input wouild be appreciated.thanks in adavnce
