Re: Fuel Cell, foam or no foam?
[Re: Thumperdart]
#2385787
10/11/17 06:12 PM
10/11/17 06:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I ran the foam in mine even with E-85.. had in there for about 10 years.. a cheap cell will have cheap foam in it and will break down after time.. if you dont run the foam I would at least look into some baffles to slow or stop the slosh.. and the slosh can be noisey.. I did a lot of noise work back at Chrysler to make tanks quiet
[Re: Mr340]
#2385799
10/11/17 06:28 PM
10/11/17 06:28 PM
Posts: 487 St Louis, MO, USA
srunge55
St Louis, MO, USA
I've been researching this topic also and there are so many varying opinions about the foam. Some say no problem others say its the worst thing to do, maybe as said above it depends on the quality of the cell/foam. My plan it to go no foam or remove the foam from the cell and run an efi in-tank pump to a carb using a bypass regulator. I'm also planning on using this deal from tanksinc to provide a baffle system for hard acceleration: http://www.tanksinc.com/index.cfm/page/p...=prod/prd84.htmAnybody else doing this? I'd love some feedback if this is a good/bad idea. Not to hijack but thought the OP might be interested also. thanks, Steve
[Re: dvw]
#2385821
10/11/17 07:19 PM
10/11/17 07:19 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Jim, I bought mine new in 1975, has foam in it. Never broke down, still using it. Just get one. It will live longer than we do.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Steve1118]
#2385860
10/11/17 08:20 PM
10/11/17 08:20 PM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
Didn't think about the noise from sloshing and thanks for the link to tanksinc, some good info there. Sounds like foam with a good filter is the way to go. oh and it will be a new cell so no issues there. Thanks for the feedback.
[Re: Mr340]
#2385889
10/11/17 09:15 PM
10/11/17 09:15 PM
Posts: 7,506 Az
Crizila
Az
I picked up a 64 dart I'm going to be setting up for some bracket racing. Since I have to replace the gas tank I figured I just go to a fuel cell, about the same price and already has a sump. Do I go with a cell with or without foam? please give me your guy's input, advantages/disadvantages.
I know the foam is supose to help with sloshing but have heard that it deterioates over time causing clogs and will need to be replace.
This is basiclly a strip car with a bit of steet use.
Thanks, Gary Per Magnafuel, no foam.
Fastest 300
[Re: Mr340]
#2386187
10/12/17 11:08 AM
10/12/17 11:08 AM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
Had a cell w/ foam in the Camaro (5 sec 1/8 mile, SBC N/A, drag only), but it started breaking down after a couple years. Removed it at that time and been that way ever since w/ no trouble.
[Re: Mr340]
#2386247
10/12/17 12:58 PM
10/12/17 12:58 PM
Superfreak
Superfreak
I have a 20gal aluminum fuel cell with the foam and now thinking about it, it would only hold about what? 5gals of fuel.
[Re: ]
#2386468
10/12/17 07:50 PM
10/12/17 07:50 PM
dogdays
You might want to read up on the foam. Here's a fuel cell foam supplier who supplies to the US military. Their foam is 98% void, meaning you lose 2% of the volume to the foam. Anyway this stuff looks like its cutting edge material. http://www.ksrfoam.com/Fuel_Cell_Foam_Kits.phpR.
[Re: Mr340]
#2386482
10/12/17 08:25 PM
10/12/17 08:25 PM
Superfreak
Superfreak
Thanks for the link, this cured my curiosity.
[Re: Crizila]
#2386641
10/13/17 12:56 AM
10/13/17 12:56 AM
Posts: 7,506 Az
Crizila
Az
Part of the problem with foam is you have no way of knowing how much fuel you have in the tank. No fuel gauge ( unless you go outside the tank with a clear tube ) and you can't visibly see the fuel level. So you use a stick to check the fuel level. Stick goes right in to the foam. Not good! You break the foam up just a little bit, and your dead meat.
Fastest 300
[Re: Crizila]
#2386657
10/13/17 02:08 AM
10/13/17 02:08 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
10 years no problem with a summit brand cel, VP C-12, and E85. I think its really hit and miss from what I have seen
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Crizila]
#2386710
10/13/17 09:41 AM
10/13/17 09:41 AM
Mr340
Richmond Twp. Mi.
Part of the problem with foam is you have no way of knowing how much fuel you have in the tank. No fuel gauge ( unless you go outside the tank with a clear tube ) and you can't visibly see the fuel level. So you use a stick to check the fuel level. Stick goes right in to the foam. Not good! You break the foam up just a little bit, and your dead meat. Looking at the offerings on Summit's page they do show cells with foam and a sending unit. https://www.summitracing.com/parts/jzp-251-116-01/overview/
[Re: Mr340]
#2386790
10/13/17 12:12 PM
10/13/17 12:12 PM
Posts: 7,506 Az
Crizila
Az
Part of the problem with foam is you have no way of knowing how much fuel you have in the tank. No fuel gauge ( unless you go outside the tank with a clear tube ) and you can't visibly see the fuel level. So you use a stick to check the fuel level. Stick goes right in to the foam. Not good! You break the foam up just a little bit, and your dead meat. Looking at the offerings on Summit's page they do show cells with foam and a sending unit. https://www.summitracing.com/parts/jzp-251-116-01/overview/ I stand rejected.
Fastest 300
