Small diameter roller cam springs #2385702
10/11/17 04:24 PM
10/11/17 04:24 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I have Harland Sharp rocker gear.
I have been told that anything above 1.50 diameter spring wont work with these rocker arms.
Was just curious( if i ever ran a roller wifh this HS setup) if anybody makes roller springs that are 1.50 or smaller OD
Just looked through the comp catalog and didnt see anything
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385705
10/11/17 04:30 PM
10/11/17 04:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran a solid roller in my 360 with eddie heads and Erson rockers. I used the K-Motion K800 with a 1.46 OD spring. My cam was a 260@.050 and .640ish lift(or close to that). I changed the springs out yearly because I was doing drag week with them but I never had a problem. This 360 made 500ish hp in good air(11.16@119.5@ 3500lbs)
68 Barracuda Formula S 340
Re: Small diameter roller cam springs [Re: B3422W5] #2385707
10/11/17 04:32 PM
10/11/17 04:32 PM
P
Porter67 Offline
Porter67  Offline
P
http://www.kmotion.biz/springdat.htm
K motion has many that will work on a small roller.
Comp also has some smaller dia springs for a mild street strip roller cam. But you have to look at there chart for outter and inner and mix and match, but K motion has always worked for me.
A comp 977-16 with the next step up inner will run a comp .525 lift street roller.
Re: Small diameter roller cam springs [Re: B3422W5] #2385708
10/11/17 04:34 PM
10/11/17 04:34 PM
P
Porter67 Offline
Porter67  Offline
P
If you decide you can use the K800 springs, ive a set with 40 minutes idle time you can have to use or test with.
If anything they only lost the initial pressure all springs do in the first hour of running.
You can go as much as a 1.900 installed on the K800 or as low a 1.800 or more.
I had a unrelated to the valve train issues and pulled it down and ended up going with a diff cam /springs.
Re: Small diameter roller cam springs [Re: B3422W5] #2385710
10/11/17 04:37 PM
10/11/17 04:37 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
That 800 spring is only 165, didnt see anything under 1.50 that would be 240-270 to run a fairly stout roller, around 1.800 ish installed height
The flat tappet i have now is around 140-145 itself.
If i went roller, have to be a sizeable upgrade over what i have
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385713
10/11/17 04:41 PM
10/11/17 04:41 PM
P
Porter67 Offline
Porter67  Offline
P
Why not have your rockers machined like many do? I know its hard to send them off to get the heck cut out of them.
But then your cutting spring pockets too.
Have you considered a tool steel or schubeck like solid lifter, I run them on a steel core at .700 lift.
I use very light valvetrain parts and seem to be able to get by on alot lighter springs then many use.
Ive spun the comps and K motions to 74-7600 and things never skipped a beat for very short time periods, just 1/8.
Im sure if you looked into the higher end springs you can find ones that will work for a bigger roller.
Re: Small diameter roller cam springs [Re: Porter67] #2385718
10/11/17 04:51 PM
10/11/17 04:51 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Thanks. Some good thoughts/ ideas.
I have a couple other changes to make on the car, and going to a roller cam might not be needed if the other changes pick the car up enough.
Probably would want to keep everything i currently have and just swap out cam and springs and retainers if i can get away with it.
I will bounce it off Dwayne, he specced the springs i am running now
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385722
10/11/17 04:57 PM
10/11/17 04:57 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Pac Spring makes alot of small od roller springs. Great parts but be prepared to pay.
Re: Small diameter roller cam springs [Re: fbs63] #2385724
10/11/17 04:58 PM
10/11/17 04:58 PM
P
Porter67 Offline
Porter67  Offline
P
Thats it right there, I like the $150 springs not the 3-400 ones, but oddly I will use $800 lifters...
Re: Small diameter roller cam springs [Re: fbs63] #2385728
10/11/17 05:00 PM
10/11/17 05:00 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Using trick flows now. Think they are a budget PAC spring, and even they are nice
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385733
10/11/17 05:05 PM
10/11/17 05:05 PM
P
Porter67 Offline
Porter67  Offline
P
If you look at at what some of the LS guys are using you will find they are using the smaller dia. springs on decent roller cams, and like I do they use the thickest 5/16 pushrod that smith bros make that smith claims will support #700 open
I forgot about the trick flow springs but recall looking at them as an option.
Re: Small diameter roller cam springs [Re: B3422W5] #2385739
10/11/17 05:09 PM
10/11/17 05:09 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
If i dont hit what i am shooting for, another option might be swapping my 1.5 intakes for 1.6 intake rockers with the cam i have
Its 565/565 lift, so with a .377 lobe that would be 603 gross lift. Might make a bit more steam opening the valves that much more?
Edit.... looks like HS gets 43 each for the 1.6 intake rockers, so about 350 bucks
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385741
10/11/17 05:14 PM
10/11/17 05:14 PM
P
Porter67 Offline
Porter67  Offline
P
Here again if you just wanted to test and dont have any 1.6-s, ive a extra tested set of the china HS that are 1.6 that ive 60 flawless runs on id loan out. I buzz them to 7500 all the time and its ironic they have better geometry the the HS units do.
Re: Small diameter roller cam springs [Re: Porter67] #2385745
10/11/17 05:21 PM
10/11/17 05:21 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Thanks. Thats an offer i might end up taking you up on. My motor has never even seen 6500 rxcept for a couple of times in the water box not being careful
1.41 best 60 foot
6.56 at 104.17
Re: Small diameter roller cam springs [Re: B3422W5] #2385748
10/11/17 05:23 PM
10/11/17 05:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Call PAC!!
Re: Small diameter roller cam springs [Re: B3422W5] #2385753
10/11/17 05:29 PM
10/11/17 05:29 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I think you're going to have a hard time finding a stiff roller spring for that particular application.
Of course, how much pressure do you really want to use with 5/16" hold down hardware?
Re: Small diameter roller cam springs [Re: B3422W5] #2385770
10/11/17 05:46 PM
10/11/17 05:46 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
I’m using a PSI spring on my W5 heads
# 1574 ML or you can buy the spring without the Max Life wire treatment # 1574.
Springs are 1.510 OD with 230@1.900 and 630@1.250 using a Comp 1730 tool steel retainer and comp locks.
I only bought the ML because I wanted the spring to last on the street.......
Re: Small diameter roller cam springs [Re: B3422W5] #2385979
10/11/17 11:40 PM
10/11/17 11:40 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have a set of freshly rebuilt Comp 828-16 lifters I am going to be selling if you need them. I also have about 4 sets of K800s with about 2000-2500 miles on each set I will throw in with the lifters.
My moderate roller cam had no trouble going to 7000 with the K800s. They also help up well to hours on the highway at 3500-4000RPM.
Re: Small diameter roller cam springs [Re: B3422W5] #2385991
10/11/17 11:52 PM
10/11/17 11:52 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Maybe you shouldn't believe everything you're told. A stock big block spring is 1.55" diameter. Do you think HS would make a rocker that couldn't be used with a stock spring? I have HS rockers, 1.55" dia. springs and no issues at all with clearance. And yes, its a solid roller cam but that makes no difference.
Re: Small diameter roller cam springs [Re: Stanton] #2385995
10/12/17 12:01 AM
10/12/17 12:01 AM
So. Burlington, Vt.
So. Burlington, Vt.
He's running a small block with rpm heads.
That combo has pretty limited space between the rocker and the spring, and HS rockers rub 1.55 springs on those heads.
It's right on the HS website, 1.50 max spring diameter.
Oh, and I'm pretty sure OE BB springs are slightly under 1.500(1.48-1.49 IIRC) not 1.550.
