Exhaust on 69 340 Swinger #2385288
10/10/17 09:33 PM
10/10/17 09:33 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What size is the factory exhaust (head pipes) on a 69 Swinger 340-4 speed.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Exhaust on 69 340 Swinger [Re: 6T9Hemi] #2385290
10/10/17 09:36 PM
10/10/17 09:36 PM
iirc the manifold outlets are ~ 2&5/16"
Re: Exhaust on 69 340 Swinger [Re: 6T9Hemi] #2385310
10/10/17 10:11 PM
10/10/17 10:11 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Factory should be 2.25".
Re: Exhaust on 69 340 Swinger [Re: 6T9Hemi] #2385333
10/10/17 10:45 PM
10/10/17 10:45 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Factory original headpipes are 2.25" O.D. except for the left flange pipe section which is 2". This downsize is for torsion bar , starter and pitman arm clearance.
Re: Exhaust on 69 340 Swinger [Re: Tom Swope] #2385394
10/11/17 12:26 AM
10/11/17 12:26 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Factory tail pipes are 1-3/4" for both 340 and 383, I used NOS ones on reproduction mufflers and had to use reducers as I know of no reproduction that are correct. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Exhaust on 69 340 Swinger [Re: Rhinodart] #2385549
10/11/17 12:06 PM
10/11/17 12:06 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Factory tailpipes for 1969 models were 2.25" O.D. at the muffler , 2" O.D. mid of the gas tank (welded connection) and sized to 1-7/8 I.D. at the rear to accept chrome tips. 1968 models were 2" O.D. at the muffler and 1-7/8 l.D. at the rear to accept chrome tips.
Applications included both 340 and 383 engines. 1967 383 models had 2" O.D. tailpipes with turn downs at the rear as chrome tips were not an option. And yes there are reproduction tailpipes available that appear as original. Accurateltd.com. We sell a lot of them.
Re: Exhaust on 69 340 Swinger [Re: Tom Swope] #2385565
10/11/17 12:27 PM
10/11/17 12:27 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I will check my NOS tail pipes this week. I bought a complete system from you EXCEPT for the tail pipes because I had the NOS pair and they would not fit the mufflers you provided. I recall measuring them then and had to get two reducers to the back of the muffler to the tail pipe. I know 67's are different but these had the factory part number tags on them for 1969. Of course this was 20 years ago and you were not reproducing the tail pipes then if I recall correctly. work
A-Body's RULE!
