451 - Valley Pan? #2384544
10/09/17 05:12 PM
10/09/17 05:12 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Searched back a couple years but couldn't find anything on a valley pan for a low deck that works well with Edelbrock RPM heads. I have the Felpro bathtub I could use or mod. Would really prefer a thick aluminum piece like Indy's use. Looks like I'd have to fab that myself which is a possibility but really like to buy a proven one that won't leak and allow me to just use regular intake gaskets.
Re: 451 - Valley Pan? [Re: 80fbody] #2384568
10/09/17 05:50 PM
10/09/17 05:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
AndyF has a set up that will work.
Re: 451 - Valley Pan? [Re: 80fbody] #2384579
10/09/17 06:06 PM
10/09/17 06:06 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Re: 451 - Valley Pan? [Re: 80fbody] #2384593
10/09/17 06:19 PM
10/09/17 06:19 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I looked at Andy's. It looks like it still requires 4 gaskets and some "batwings" that he sells. Really would like to get away from all that. But that may not be possible with the RPM's. Hopefully he'll chime in on this as well as he may have tried to do a plate without involving the intake faces & it didn't seal.
Re: 451 - Valley Pan? [Re: 80fbody] #2384615
10/09/17 06:40 PM
10/09/17 06:40 PM
AndyF Offline
AndyF  Offline
What you are looking for does not exist and will not ever exist.
Re: 451 - Valley Pan? [Re: 80fbody] #2384693
10/09/17 08:25 PM
10/09/17 08:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use the Fel-pro pan w/my lo deck and standard port Eddy's but w/Superformance gaskets cos the paper junk leaks and my manifold/heads haven't been this dry ever............. thumbs
Re: 451 - Valley Pan? [Re: AndyF] #2384734
10/09/17 09:37 PM
10/09/17 09:37 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Well I may have to have one made for me on a CNC.
Re: 451 - Valley Pan? [Re: Thumperdart] #2384736
10/09/17 09:40 PM
10/09/17 09:40 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
I've got a new felpro tub. Gonna grab some superformance gaskets as it sounds like the way to go if I can't fab something up.
Re: 451 - Valley Pan? [Re: 80fbody] #2384760
10/09/17 10:28 PM
10/09/17 10:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I put Andy's plate and batwing set-up on my 512 lo deck and to tell you the truth it is a very nice way of doing it and the best part is,,,,,no leaks, very sturdy and looks great, I highly reccomend it.
Re: 451 - Valley Pan? [Re: dartman366] #2384772
10/09/17 10:40 PM
10/09/17 10:40 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Thanks. Wasn't sure about that setup. Thanks for that. Andy does produce nice stuff for sure.
Re: 451 - Valley Pan? [Re: 80fbody] #2384811
10/09/17 11:36 PM
10/09/17 11:36 PM
AndyF Offline
AndyF  Offline
A CNC can't make something that can't be designed. If you look at a set of RPM heads mounted on a block you'll see that there isn't any place for a billet valley plate to seal to the head.
Re: 451 - Valley Pan? [Re: 80fbody] #2384965
10/10/17 10:29 AM
10/10/17 10:29 AM
an8sec70cuda Offline
I have not tried to do what the OP wants, but I'm thinking it's similar to what I've done on my hemi. Using an Indy valley tray and Indy intake on regular MP heads. The heads don't overlap onto the valley cover like the Indy heads do, it just leaves a slight gap in the V groove where they meet. Fill the gap w/ a bead of silicone, then you can set the intake gaskets on w/ the intake.
Some people may not like the amount of silicone needed, but it does work.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 451 - Valley Pan? [Re: an8sec70cuda] #2384989
10/10/17 11:22 AM
10/10/17 11:22 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
Andy's Batwing setup works great! I used to do it with a Indy plate and The Right Stuff but his is the way to go. twocents
Re: 451 - Valley Pan? [Re: an8sec70cuda] #2385066
10/10/17 01:11 PM
10/10/17 01:11 PM
AndyF Offline
AndyF  Offline
Yes you can do that. The billet valley cover will leave a v notch on each side which can be filled in with RTV. This works better if the engine has pan vacuum than if it has a lot of blowby. With pan vacuum the RTV gets sucked into the V groove and seals up. If it is a street engine and it has blowby then the pan pressure will blow the RTV out over time since there is nothing to hold it there. That is the whole idea of the batwings. The batwings are thin aluminum but that is all that is needed to reinforce the RTV.
Re: 451 - Valley Pan? [Re: AndyF] #2385089
10/10/17 02:13 PM
10/10/17 02:13 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
That makes sense.
Re: 451 - Valley Pan? [Re: 80fbody] #2385094
10/10/17 02:21 PM
10/10/17 02:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you use Great Stuff it will firm up harder
than just silicone.. but it can be a PITA to
get apart.. but on a manifold you should be
able to
wave
Re: 451 - Valley Pan? [Re: 80fbody] #2385101
10/10/17 02:31 PM
10/10/17 02:31 PM
AndyF Offline
AndyF  Offline
This is what it looks like before you start filling in with RTV. You can't go very deep with the RTV since the intake manifold needs to seal around ports.
Re: 451 - Valley Pan? [Re: 80fbody] #2385107
10/10/17 02:43 PM
10/10/17 02:43 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
That's a great pic. Definitely can see how it's tough to create a seal there.
Re: 451 - Valley Pan? [Re: AndyF] #2385199
10/10/17 06:01 PM
10/10/17 06:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
Not to mention the fact that some intake manifold gasket flanges extend below the deck surface of the head.
Re: 451 - Valley Pan? [Re: 80fbody] #2385200
10/10/17 06:13 PM
10/10/17 06:13 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I just used the factory style pan and the right stuff, no gaskets. painted it with the engine. It has always worked great on any B-RB I've ever had.
