Door hinge bushings #2384799
10/09/17 11:21 PM
10/09/17 11:21 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
What is the best way to replace door hinge bushings on a 69 A body. Upper hinge.
1969 340 4 Speed Swinger R4,
black vinyl, white butt stripe, 3:91
Re: Door hinge bushings [Re: 6T9Hemi] #2384919
10/10/17 03:04 AM
10/10/17 03:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
For the smaller upper hinge that came with factory bushings, simply tap out the old bushings and tap in new bushings with a new pin.
The larger lower hinges that had no factory bushings should only be rebuilt by drilling and reaming and installing an oversized pin, not by installing bushings where there weren't any. Here's a link to a good kit. Don't buy kits that include bushings for lower hinges.
Re: Door hinge bushings [Re: kentj340] #2384937
10/10/17 09:05 AM
10/10/17 09:05 AM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Do the hinges only bolt on one way or is there adjustment in the hinges?
Re: Door hinge bushings [Re: 6T9Hemi] #2385028
10/10/17 12:28 PM
10/10/17 12:28 PM
NJ
rth Offline
rth  Offline
NJ
The hindge itself doesn't have an adjustment. The adjustment is the cowl holes are oversized, squared off. That's how you adjust them. Same for door side of hindge.
Re: Door hinge bushings [Re: rth] #2385122
10/10/17 03:14 PM
10/10/17 03:14 PM
Elizabethtown, KY
6T9Hemi Offline OP
6T9Hemi  Offline OP
Elizabethtown, KY
Thanks, that's what I was asking, if there was adjustment in the bolt holes.
