2001 Ram, 318, 4X4 Died; P0455 and P0420 Codes
#238421
02/27/09 10:03 PM
02/27/09 10:03 PM
Posts: 3,096 N.W. Florida
Fat_Mike
N.W. Florida
I was driving home last night when my truck suddenly spit, sputtered, and then died, all within about 10 seconds. Prior to that, there was indication that anything was wrong. I've been ignoring the P0455 for quite awhile now. After it died, I did the self-diagnostic check and saw the P0420 code that indicates something is wrong with the catalitic converter. I do have a small exhaust leak, so perhaps that code can be attributed to that. So I guess the question is: Where do I start???
Re: 2001 Ram, 318, 4X4 Died; P0455 and P0420 Codes
[Re: Fat_Mike]
#238426
03/01/09 11:47 AM
03/01/09 11:47 AM
Fat_Mike
N.W. Florida
Thanks for the replies! I tried a number of things to include checking all the fuses, checking for spark, looking "obvious" stuff under the hood, and disconnecting the battery to clear the codes. As a last resort, I put a few gallons of gas it just to see if maybe my guage was off. It read about 1/16th full (still well above the red), and I don't recall ever running that low before. After cranking it, tinkering around and cranking again, it finally fired. I'm still not 100% convinced that's the problem. I guess my next step will be to address those codes. I'll just have to keep it out of the woods until I regain my confidence in it. Anyone know if the gas guage in this era truck is inherently off???
[Re: FuryUs]
#238428
03/01/09 02:55 PM
03/01/09 02:55 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Mine has run out showing 1/16th before and I have driven it below the e line. I don't know if they stick sometimes or what happens. My 94 trans am has done this too.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
