Block Time Frame #2384016
10/08/17 06:02 PM
10/08/17 06:02 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
For a RR built at the end of April in 71, what would be a good cast date for a 383 block? Thanks
Re: Block Time Frame [Re: 71birdJ68] #2384084
10/08/17 08:26 PM
10/08/17 08:26 PM
Are you trying to find one that could be made "numbers matching" work tsk
Any block with a casting date before two to three weeks before the SPD to allow for machining and transporting the engine to the assembly plant would make since to me shruggy
Same thing on all the other parts on that motor shruggy
Re: Block Time Frame [Re: 71birdJ68] #2384092
10/08/17 08:44 PM
10/08/17 08:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Years. Months. Weeks. Days.
Pick one.
Without your original block, there is no way to know what dates it had.
Re: Block Time Frame [Re: 71birdJ68] #2384099
10/08/17 08:53 PM
10/08/17 08:53 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I recently helped a friend rebuild a 1971 C-body 383 that had a 1969 casting date.
Stan
Re: Block Time Frame [Re: Cab_Burge] #2384121
10/08/17 09:45 PM
10/08/17 09:45 PM
Morristown Tn.
Morristown Tn.
No, not trying to cheat, just wanting a correct time frame.
Re: Block Time Frame [Re: 71birdJ68] #2384199
10/09/17 12:03 AM
10/09/17 12:03 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you are looking for something that visually appears correct, I'd recommend going for the correct stamping on the distributor pad, not the block casting date.
Re: Block Time Frame [Re: 6PakBee] #2384212
10/09/17 12:26 AM
10/09/17 12:26 AM
Morristown Tn.
Morristown Tn.
What would that be?
Re: Block Time Frame [Re: 71birdJ68] #2384261
10/09/17 02:32 AM
10/09/17 02:32 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
G 383 HP & a date on the pad under the distributor
if you want to get crazy - get a '71 383HP with a VIN stamping from the same plant as the subject car: "1G123456" or "1R102030" etc.
here's a '70 "F 383 HP" scope
Re: Block Time Frame [Re: 6bblgt] #2384301
10/09/17 09:37 AM
10/09/17 09:37 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I recently acquired a 71 383 and it had a cast crank, did all 71 383's have cast cranks or just the non-hp blocks? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Block Time Frame [Re: 71birdJ68] #2384305
10/09/17 09:44 AM
10/09/17 09:44 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Your going to want to find a G 383 HP block with an EAD {eng. assembly date} approximately a month or two before your SPD.
Re: Block Time Frame [Re: 71birdJ68] #2384436
10/09/17 01:50 PM
10/09/17 01:50 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I don't understand the purpose of this. shruggy
What are you trying to tell people? whistling
If it isn't the original motor,
what difference does it make at this point?
I have mechanical Aptitude.
I can screw up anything.
Re: Block Time Frame [Re: bboogieart] #2384441
10/09/17 01:56 PM
10/09/17 01:56 PM
Morristown Tn.
Morristown Tn.
Everything I have done, I have tried to have things with the proper date codes. Just for my own satisfaction.
Re: Block Time Frame [Re: Rhinodart] #2384456
10/09/17 02:25 PM
10/09/17 02:25 PM
Most of the 1971 2 barrel motors had cast cranks, why I do not know confused
Re: Block Time Frame [Re: 71birdJ68] #2384537
10/09/17 05:00 PM
10/09/17 05:00 PM
blewbyu Offline
blewbyu  Offline
My original 440 Assy date is 2 weeks before the SPD
Re: Block Time Frame [Re: Rhinodart] #2384685
10/09/17 08:02 PM
10/09/17 08:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Only 2-barrel 383's got the cast crank in '70-'71. Why? Money, why waste more expensive forgings on a lo-po motor.
Re: Block Time Frame [Re: 71birdJ68] #2384803
10/09/17 11:23 PM
10/09/17 11:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The original engine in my T/A had a final assembly date of April 22, 1970.
It had a SPD of 417, so it was built later than 'hoped for' when the order was first entered into the system.
It had an April door sticker, so I know the car was actually assembled after April 22 but before the month of May.
Some of the glass in it was dated way early, June of 1969.
But to have that type of detail, you have to know what it came with.
If not?
No way to know.
Impossible questions to answer result in answers impossible to make.
Re: Block Time Frame [Re: blewbyu] #2385615
10/11/17 01:46 PM
10/11/17 01:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The original 383 for my Super bee ASSY date is 1 day after the SPD on the tag ... both are original pieces ... it can be all over the place and the later in the musclecar era the longer the gap could be???
Casting date has to be before the ASSY date obviously , I have seen as close as 3 weeks myself, some have been closer. Hemis are all over the map and I know of a 71 6pk car that ASSY date was months before SPD.
It's never going to be original so get whatever you can that is before ...
