Hemi block ID help #2383287
10/07/17 03:13 AM
10/07/17 03:13 AM
AndyF Offline OP
AndyF  Offline OP
I can see that it is a '68 casting and was used in a '70 model year but I'm not sure what some of the other stampings mean. I think the '69 date is an assembly date but I'm not sure about the MN or is it an upside W? The WT is water test. Is the MN for Marysville Plant?
In the VIN the 0 is for '70 and the B is Hamtramck? So this block could be from a '70 Hemi Cuda or Challenger?
DSC_1458 (Large).JPGDSC_1459 (Large).JPGDSC_1461 (Large).JPGDSC_1462 (Large).JPG
Re: Hemi block ID help [Re: AndyF] #2383288
10/07/17 03:15 AM
10/07/17 03:15 AM
AndyF Offline OP
AndyF  Offline OP
Here is a closer view of the VIN
Re: Hemi block ID help [Re: AndyF] #2383290
10/07/17 03:38 AM
10/07/17 03:38 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
MN42630035319
MN= Plant identifier for the Marysville engine plant
426= Displacement
3003= Build date October 17, 1969
5319= Sequence number
Re: Hemi block ID help [Re: John_Kunkel] #2383294
10/07/17 03:57 AM
10/07/17 03:57 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Originally Posted By John_Kunkel
MN42630035319
426= Displacement
53193= Sequence number
there's a fifth digit to the sequence number for 1970 model year & the partial VIN indicates it is/was a hemi'cuda drive
Re: Hemi block ID help [Re: AndyF] #2383295
10/07/17 04:06 AM
10/07/17 04:06 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
the B on the top pad and rail corresponds to 0.010 under size main and rod bearings
fwiw it's rather cool to see a block like this with original machining marks and stamps.
Re: Hemi block ID help [Re: srt] #2383296
10/07/17 04:10 AM
10/07/17 04:10 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Originally Posted By srt
the B corresponds to 0.010 under size main and rod bearings
the crank would be undersize & the bearings oversize beer
Re: Hemi block ID help [Re: 6bblgt] #2383297
10/07/17 04:17 AM
10/07/17 04:17 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
now I'm confused...
oversized rod bearings means *smaller* rod journals on the crank?
I got the mains (if it can be bored straight and leave material it's good). I always figured it meant the crank rod journals were finished to a greater diameter for future cutting too
Re: Hemi block ID help [Re: srt] #2383299
10/07/17 04:30 AM
10/07/17 04:30 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
no, it is smaller diameter crank main & rod journals
it was done at the factory to use crankshafts that didn't machine with the desired surface finish at STANDARD OD size
on a block:
piston bores & lifter bores can be oversize on a factory block, because once the material is removed - larger is the cheapest way to go for a "fix"
block main/caps & rod/caps (because there are two halves) can be machined & returned to the STANDARD ID
Re: Hemi block ID help [Re: 6bblgt] #2383362
10/07/17 12:28 PM
10/07/17 12:28 PM
AndyF Offline OP
AndyF  Offline OP
MN42630035319
426= Displacement
there's a fifth digit to the sequence number for 1970 model year & it is/was a hemi'cuda drive
So the 3 after the sequence number means 'Cuda? I did not know that. I've never seen any info on decoding the sequence numbers.
Re: Hemi block ID help [Re: AndyF] #2383372
10/07/17 12:46 PM
10/07/17 12:46 PM
Hamtramck, PA
Alaskan_TA Online content
Fluffy Balladeer
Alaskan_TA  Online Content
Fluffy Balladeer
Hamtramck, PA
No, it does not.
It does match a 1970 Hemi Cuda though.
I do have an email contact for the car owner, I just sent him a link to this thread.
Re: Hemi block ID help [Re: Alaskan_TA] #2383385
10/07/17 01:11 PM
10/07/17 01:11 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Originally Posted By Alaskan_TA
No, it does not.
Way to go Barry! Bet you just made his day, just like your efforts have done many times in the past. I remember years ago, you hooked up the owner of an AAR with a kid who had his TA motor in his Dart that I sent you the VIN # of. Thanks for being an asset to the Mopar community.
Re: Hemi block ID help [Re: AndyF] #2383428
10/07/17 02:19 PM
10/07/17 02:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
MN42630035319
426= Displacement
The sequence number has nothing to do with what car it went into.
The VIN on the block told them it went into a cuda. Serial numbers were issued in groups or blocks so if you know the group range you can surmise what type of car it went into.
Re: Hemi block ID help [Re: Alaskan_TA] #2383453
10/07/17 03:50 PM
10/07/17 03:50 PM
AndyF Offline OP
AndyF  Offline OP
No, it does not.
That could be good or bad. If the guy already has a "numbers matching" block in his car then seeing this thread isn't going to make his day.....
I should say that this is not my block. I saw the block sitting in a shop the other day and it was so clean and the stamps so clear that I thought I'd shoot some pictures of it just to see what it was. The engine appears to be complete with original intake, carbs, crank, rods, etc. all sitting there. I do not know the back story on the engine but if the owner of the car wants to contact me I could tell them where I saw the engine and they could take it from there. The shop was planning to rebuild the engine so if the car owner wants to buy it before it gets rebuilt then they'll have to make a quick decision.
Re: Hemi block ID help [Re: AndyF] #2383457
10/07/17 04:00 PM
10/07/17 04:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I guess that would depend on whether or not he paid numbers matching money for the car but got a re-stamped block in the deal instead, otherwise I'd guess it wouldn't be a bad thing at all.
I'd be doing the happy dance big time if it were my car and there was an opportunity to get my numbers block back, has the block ever been hurt or repaired Andy?
Re: Hemi block ID help [Re: AndyF] #2383460
10/07/17 04:04 PM
10/07/17 04:04 PM
California
mickm Offline
mickm  Offline
California
Andy, I know what you mean. Could be quite expensive to obtain this block, and then build a whole new engine for your car, but may well be worth it for the owner.
Can we keep this thread going with updates? I would love to hear if anything comes of this.
Re: Hemi block ID help [Re: mickm] #2383480
10/07/17 04:50 PM
10/07/17 04:50 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Maybe they could work a deal to swap blocks?
Re: Hemi block ID help [Re: ScottSmith_Harms] #2383483
10/07/17 04:52 PM
10/07/17 04:52 PM
AndyF Offline OP
AndyF  Offline OP
Block appeared to be perfect to me. It is 0.030 over and it had old style pistons in it so perhaps it was rebuilt in the 80's or something. I didn't see any damage to anything. Crank looked factory fresh. I didn't spend a bunch of time examing parts since it isn't my motor and I don't know who owns the motor. I just happened to see this super clean Hemi block sitting on the floor and asked if I could shoot some pictures of it. I had never seen the rail stampings so nice and crisp. Thought it was the best original Hemi block I'd ever seen.
Re: Hemi block ID help [Re: AndyF] #2383486
10/07/17 05:00 PM
10/07/17 05:00 PM
P
Porter67 Offline
Porter67  Offline
P
I know you are/were just trying to help and alot do it but this is why myself and many do not post specific info about others property without direct permission or in some cases our own cars on the web. Some do not favor the internet.
There are 3-4-5 on this board who could of helped with the vin info via pm.
Re: Hemi block ID help [Re: 6bblgt] #2383499
10/07/17 05:47 PM
10/07/17 05:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I realize that but according to Galen's White Book "Any numbers found after those 13 digits are of no meaning." shruggy
Re: Hemi block ID help [Re: Alaskan_TA] #2383783
10/08/17 11:23 AM
10/08/17 11:23 AM
E
earlymopar Offline
earlymopar  Offline
E
I for one am interested in knowing how you identified this as coming from a specific car. I understand there is a link to the VIN but don't understand how the link is made.
- EM
