1996 Ram 1500 Steering Column Issue
#2383602
10/07/17 10:11 PM
10/07/17 10:11 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I just picked up a 96 Ram 1500 with tilt wheel. When you tilt the column down with the headlights on, the headlights flicker and/or go off. Common issue? I'm guessing the wiring to/from the multi/function switch is compromised. Just looking for info and suggestions, such as easier to pull column or not, etc. Thanks.
Free advice and worth every penny... Factory trained Slinky rewinder.........
Re: 1996 Ram 1500 Steering Column Issue
[Re: J_BODY]
#2383707
10/08/17 02:13 AM
10/08/17 02:13 AM
Evil Spirit
Newport, Mi
Sounds like a good place to start looking - thanks.
[Re: Evil Spirit]
#2385998
10/12/17 12:05 AM
10/12/17 12:05 AM
Evil Spirit
Newport, Mi
I ordered a remote start unit and figured I'd wait to address the headlight issue when I install the start box. I expect your suggestion to be correct, since the previous owner used the tilt function every time he drove the truck. I will post what I find and my repair method.
