1996 Ram 1500 Steering Column Issue #2383602
10/07/17 10:11 PM
10/07/17 10:11 PM
Newport, Mi
Evil Spirit Offline OP
Newport, Mi
I just picked up a 96 Ram 1500 with tilt wheel. When you tilt the column down with the headlights on, the headlights flicker and/or go off. Common issue? I'm guessing the wiring to/from the multi/function switch is compromised. Just looking for info and suggestions, such as easier to pull column or not, etc. Thanks.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 1996 Ram 1500 Steering Column Issue [Re: Evil Spirit] #2383627
10/07/17 11:23 PM
10/07/17 11:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Isn't the column covered by a couple of removable plastic pieces?
Re: 1996 Ram 1500 Steering Column Issue [Re: Evil Spirit] #2383704
10/08/17 02:05 AM
10/08/17 02:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
wire pulled out of the connector for the multifunction switch.... seen this a bunch of times.
Re: 1996 Ram 1500 Steering Column Issue [Re: J_BODY] #2383707
10/08/17 02:13 AM
10/08/17 02:13 AM
Newport, Mi
Newport, Mi
Sounds like a good place to start looking - thanks.
Re: 1996 Ram 1500 Steering Column Issue [Re: Evil Spirit] #2385529
10/11/17 11:29 AM
10/11/17 11:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
any news?
Re: 1996 Ram 1500 Steering Column Issue [Re: Evil Spirit] #2385998
10/12/17 12:05 AM
10/12/17 12:05 AM
Newport, Mi
Newport, Mi
I ordered a remote start unit and figured I'd wait to address the headlight issue when I install the start box. I expect your suggestion to be correct, since the previous owner used the tilt function every time he drove the truck. I will post what I find and my repair method.
