Weird lighting issue with Autometer gauges #2383585
10/07/17 09:39 PM
10/07/17 09:39 PM
Fallon, Nv
SeventyGTX Offline OP
Fallon, Nv
I put two Autometer gauges in my Ram today, a boost gauge and stepper motor type fuel pressure. I tied the lights into the headlight/dimmer switch, just like I did for the Air Lift gauge. The weird thing is, the lights come on fine on both the new gauges, but the dimmer doesn't work for the boost gauge.
I double checked the wiring and have both light wires tied together going into the headlight switch wire. Both are also tied together to a common ground. This is really bizarre and I have no idea what to look for. Anyone ever have this problem?
Re: Weird lighting issue with Autometer gauges [Re: SeventyGTX] #2383587
10/07/17 09:45 PM
10/07/17 09:45 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Is the boost gauge LED light?
Most LED will work on a range of voltage
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Weird lighting issue with Autometer gauges [Re: SeventyGTX] #2383589
10/07/17 09:46 PM
10/07/17 09:46 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Are the gauges the LED lit ones or the regular lamp ones?
LEDs can be flaky when it comes to dimming them...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Weird lighting issue with Autometer gauges [Re: moparts] #2383599
10/07/17 10:04 PM
10/07/17 10:04 PM
Fallon, Nv
Fallon, Nv
Yes, they are both LED, as well as the Air Lift gauge light. Well, I assume they are LED as they are internal and cannot be removed like the old style.
It has two male spades out the back, one marked 12v. I just went out and reversed them just for grins, and got not light at all on the boost. Flipped them back where they belong and it still works, but no dimming.
Re: Weird lighting issue with Autometer gauges [Re: SeventyGTX] #2383651
10/08/17 12:21 AM
10/08/17 12:21 AM
Fallon, Nv
Fallon, Nv
Now that it's dark out, I went out to see how bright they are and they are BRIGHT. I think even dimmed down, the fuel pressure gauge is brighter than the factory gauges at full bright. So, I imagine I will just live with it. Since they are on the steering column, I will just throw a rag over them if they are too bright at night.
Re: Weird lighting issue with Autometer gauges [Re: SeventyGTX] #2383657
10/08/17 12:35 AM
10/08/17 12:35 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I ran into this with an autometer c2 trans temp gauge.
iirc the factory instruments are dimmed from the (-) side and will not dim the led of am gauges.
To make it work for me I installed it on the hump by the transfer case shifter so the light wouldn't bug me.
Autometer has an add-on dimmer you can set and leave as desired bright/dim, or you can get a (I think) 1/4 watt 475 ohm resistor and wire it inline on the gauge light (+) power supply.
Re: Weird lighting issue with Autometer gauges [Re: SeventyGTX] #2383850
10/08/17 01:18 PM
10/08/17 01:18 PM
Port Huron, Michigan
MI_Custumz Online content
MI_Custumz  Online Content
How about trying some window tint on them?
