Alignment specs for 2012 Jeep Patriot needed #2383477
10/07/17 04:42 PM
10/07/17 04:42 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi does anyone have a source to look up the toe setting for a 2012 Jeep Patriot Latitude 2.4 5 speed AWD? I just put in a tie rod end for my wife and now I need to check the toe.
Thanks,
Joel
Re: Alignment specs for 2012 Jeep Patriot needed [Re: Hemi_Joel] #2383496
10/07/17 05:36 PM
10/07/17 05:36 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
GAS ENGINE
4x2, 4x4 without OFF-ROAD GROUP (AWL), and Export
FRONT WHEEL ALIGNMENT
PREFERRED SETTING
ACCEPTABLE RANGE
CAMBER
-0.64°
-1.19° to -0.09°
Cross Camber (Maximum Side-To-Side Difference)
0.00°
-0.60° to +0.60°
CASTER* - LEFT
+3.00°
+2.00° to +4.00°
CASTER* - RIGHT
+2.70°
+1.70° to +3.70°
Cross Caster (Maximum Side-To-Side Difference)
0.30°
-0.70° to +1.30°
TOE - TOTAL**
+0.20°
0.00° to +0.40°
Notes:
* For reference only. These are nonadjustable angles.
** TOTAL TOE is the sum of both the left and right wheel toe settings. TOTAL TOE should be equally split between each wheel on the same axle to ensure the steering wheel is centered after setting toe.
Positive toe (+) is toe-in and negative toe (−) is toe-out.
Re: Alignment specs for 2012 Jeep Patriot needed [Re: Hemi_Joel] #2383535
10/07/17 07:18 PM
10/07/17 07:18 PM
Minnesota
Minnesota
Thanks!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
