will rear driveline from 78 W150 fit 81 W150 #2383438
10/07/17 03:12 PM
10/07/17 03:12 PM
Mid west
C_stripes Offline OP
Mid west
Will the rear driveline from a 78 Dodge Power wagon standard cab short box with full-time 4x4 fit an 81 W150 standard cab short box with part time 4x4? I am needing a driveline for my daily driver 81 and cant seem to find one. We have a parts 78 that should be home in the next couple weeks and has the rear. Just wondering if I need to keep looking. Thanks, Jeremy
Re: will rear driveline from 78 W150 fit 81 W150 [Re: C_stripes] #2383746
10/08/17 09:37 AM
10/08/17 09:37 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Check the universal joint size.
I would guess it will bolt in.
I swapped an 84 rear axle under a 76, but they were the D-200.
Only thing was lug stud size was different.
Never even noticed till I tried to install aftermarket wheels. shocked
I have mechanical Aptitude.
I can screw up anything.
Re: will rear driveline from 78 W150 fit 81 W150 [Re: C_stripes] #2384105
10/08/17 09:07 PM
10/08/17 09:07 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Rear driveshaft or axle?
Either way I'd guess no.. certainly not the axle, bolt pattern is different.
Transfer cases are different lengths, how different I'm not sure.
Angry white pureblood male
Re: will rear driveline from 78 W150 fit 81 W150 [Re: ruderunner] #2384122
10/08/17 09:46 PM
10/08/17 09:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Believe he means driveshaft. Bet it still uses small joint, but I am not sure of different length because of change to alum transfer case.
Re: will rear driveline from 78 W150 fit 81 W150 [Re: buildanother] #2384220
10/09/17 12:50 AM
10/09/17 12:50 AM
Alberta
440_Offroader Offline
Alberta
Could be a 9 1/4" or a 8 1/4" either way as well. If both are the same, you could swap the axles for the correct bolt pattern. If not the same, your pinion length will probably different and I think your driveshaft will be a problem. The 203 T-case has a bolt on yoke and the driveshaft will have the slip built in. The 208 will have a slip yoke with a solid driveshaft. Guess you'll have to see what you have when the truck shows up.
Re: will rear driveline from 78 W150 fit 81 W150 [Re: C_stripes] #2384967
10/10/17 10:30 AM
10/10/17 10:30 AM
scratchnfotraction Offline
yes, rear axle housings all share the 43" perch centers
72-93 bolts in but may or may not need drive shaft cut.
85-93 had the larger wbp 5 on 5.5 IIRC c-clip change keeps them from swapping axles on 9 1/4 to 9 1/4
72-74 w100 & C-body&wagon 8 3/4 housing/axles are same width as truck and bolt in with a perch change on a 8 3/4 car housing.
A-body 8 3/4 bolts in and tucks 12" rims in the fenders on a truck
drive shafts? shop & chop to build as needed.
