Re: edelbrock 600 cfm carb not fueling carb bowls
[Re: moparpro]
#2382701
10/05/17 10:15 PM
10/05/17 10:15 PM
RapidRobert
Did it start? if not then I'd pull the top & checkout the floats/needle/seats. If it started but no AP squirt then I would take the top off & see if the ball bearing is under the pump plunger (iirc it has one). Wouldn't hurt to lightly lube the bowl screws with WD40 or some light oil, not a deal breaker but for alot of screw removal it helps maintain the alum bowl threads.
[Re: moparpro]
#2382711
10/05/17 10:30 PM
10/05/17 10:30 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I think he means there is no fuel going into the fuel bowls.
Either the check valve are both stuck, the feed lines and passageways are plugged or it's not getting past the filter.
[Re: moparpro]
#2383254
10/07/17 01:09 AM
10/07/17 01:09 AM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
if the fuel is coming up TO the filter, is it getting THRU the filter?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
