edelbrock 600 cfm carb not fueling carb bowls #2382690
10/05/17 09:59 PM
10/05/17 09:59 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
carb was rebuilt last year and never used until now,gas comes up to fuel filter,but will not squirt inside bowls,any ideas? thanks
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2382701
10/05/17 10:15 PM
10/05/17 10:15 PM
Did it start? if not then I'd pull the top & checkout the floats/needle/seats. If it started but no AP squirt then I would take the top off & see if the ball bearing is under the pump plunger (iirc it has one). Wouldn't hurt to lightly lube the bowl screws with WD40 or some light oil, not a deal breaker but for alot of screw removal it helps maintain the alum bowl threads.
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2382711
10/05/17 10:30 PM
10/05/17 10:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think he means there is no fuel going into the fuel bowls.
Either the check valve are both stuck, the feed lines and passageways are plugged or it's not getting past the filter.
Don't be the exception.
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: Supercuda] #2382769
10/05/17 11:59 PM
10/05/17 11:59 PM
Yes, more info please.
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2382784
10/06/17 12:41 AM
10/06/17 12:41 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2383075
10/06/17 06:48 PM
10/06/17 06:48 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No fuel in the bowls, needles stuck on both sides, highly unlikley. No squirt from the pump. Now thats a possibilty. Either the pump plunger seal is dried and shrunk or the outlet check weight under the nozzle is stuck. Ive seen both.
Doug
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2383247
10/07/17 12:50 AM
10/07/17 12:50 AM
md
mopars4ever Offline
mopars4ever  Offline
md
As stated if no fuel in bowls then it would be a stuck needle or improperly adjusted or a blockage at the inlet. If gas is in the bowls I would make sure they used the correct bowl gaskets or if they were installed correctly.
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2383254
10/07/17 01:09 AM
10/07/17 01:09 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
if the fuel is coming up TO the filter, is it getting THRU the filter?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: edelbrock 600 cfm carb not fueling carb bowls [Re: moparpro] #2383317
10/07/17 10:21 AM
10/07/17 10:21 AM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
Fuel filter on backwards??
