Re: Subframe connectors?
[Re: topside]
#2382437
10/05/17 02:48 PM
10/05/17 02:48 PM
Posts: 4,672 Wichita
GY3
Wichita
I did subframe connectors first just 2x2 so I didn't have to cut the floor. It made a HUGE difference in the feel of the car. I recently added a 6pt. bar and was suprised it felt even better!
Anything you can do to stiffen our unibodies helps!
[Re: 70Drop]
#2382453
10/05/17 02:59 PM
10/05/17 02:59 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A bodies are flimsy. Sub frame connectors are the first thing to do. Welded, and I prefer to section into or at least tie them into the floor somehow. Firewalls are also flimsy, that is usually addressed with a full cage.
[Re: 70Drop]
#2382506
10/05/17 04:15 PM
10/05/17 04:15 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
They make a HUGE difference. Make sure to install the two angled bars off the main hoop through the rear sear footwell to connect with the frame connectors, basically that makes a 6 point an 8 point and is an extremely good upgrade. Doing all this makes the car " one piece" your doors will thank you by continuing to shut properly
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: 70Drop]
#2382539
10/05/17 05:16 PM
10/05/17 05:16 PM
Posts: 4,206 New York
polyspheric
New York
3" tall, through the floor.
Boffin Emeritus
[Re: polyspheric]
#2382597
10/05/17 07:00 PM
10/05/17 07:00 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3" tall, through the floor. Short of a 25.x chassis, this is most effective.
[Re: 70Drop]
#2382716
10/05/17 10:35 PM
10/05/17 10:35 PM
polyspheric
New York
IIRC 3" still keeps the floor mostly intact. For those not familiar, the bending resistance improvement between 2" and 3" is huge: more than 2-1/2 times with only a 25% weight penalty.
Boffin Emeritus
[Re: 70Drop]
#2382770
10/05/17 11:59 PM
10/05/17 11:59 PM
polyspheric
New York
... before you wrinkle the "C" pillar on a hard launch!
Boffin Emeritus
[Re: CMcAllister]
#2382884
10/06/17 11:09 AM
10/06/17 11:09 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
3" tall, through the floor. Short of a 25.x chassis, this is most effective. Yes, Mine are round tube chrome moly & tie in with the cage on my Challenger and go thru the torsion bar support & front frame rails. The short bar show with tab is my removable drivesahft loop mount that goes from frame connector to frame connector & meets the 25.5 rule about having the under car cross bar.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 70Drop]
#2383157
10/06/17 09:58 PM
10/06/17 09:58 PM
polyspheric
New York
If you're not sure the boxes are water-tight, drill small drain holes at the lowest points so that water doesn't accumulate. Someone I know has simply caulked the ends with silicone (very clean first!) and it's been dry for years.
Boffin Emeritus
