Re: 70 Challenger brakes
[Re: Carsavior]
#2381887
10/04/17 06:01 PM
10/04/17 06:01 PM
Posts: 2,379 White Plains, NY
VCODE
White Plains, NY
Also check to see if the master cylinder rod is adjusted and has about .30 play and is not keeping the brakes on. Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#2381919
10/04/17 06:19 PM
10/04/17 06:19 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Also check to see if the master cylinder rod is adjusted and has about .30 play and is not keeping the brakes on. Bob Make that .03" Not .30". .30 is almost 5/16th of an inch, which is more than 1/4 inch, WAY too much. :-)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2382040
10/04/17 08:05 PM
10/04/17 08:05 PM
VCODE
White Plains, NY
Also check to see if the master cylinder rod is adjusted and has about .30 play and is not keeping the brakes on. Bob Make that .03" Not .30". .30 is almost 5/16th of an inch, which is more than 1/4 inch, WAY too much. :-) thanks, turned number around while typing.
[Re: Carsavior]
#2382132
10/04/17 11:17 PM
10/04/17 11:17 PM
RapidRobert
new calipers & it is still dragging? Both sides dragging or just one? You might jack up the front end & hit the brakes to get em dragging then loosen a caliper bleeder to see if it is a psi or a mechanical (caliper) problem tho with both sides acting up at the same time all of a sudden for sure sounds like a psi issue. As said if power then check the pushrod round nub clearance. Post how it turns out. EDIT If power I would remove the 4 MC nuts & space the MC slightly forward from the booster with some washers & see if that resolves it & if so then I would go ahead & seperate the MC from the booster & measure the gap/shorten the rounded pushrod nub to get ~.020" gap.
[Re: Carsavior]
#2382720
10/05/17 10:41 PM
10/05/17 10:41 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The combination valve is a combination of proportion and metering in one assembly.
[Re: Supercuda]
#2382766
10/05/17 11:52 PM
10/05/17 11:52 PM
RapidRobert
I'm assuming when you crack the "out" line from the prop valve forward to the front calipers that they release?
[Re: Carsavior]
#2382821
10/06/17 02:19 AM
10/06/17 02:19 AM
RapidRobert
iirc a guy used no valve at all with 4 wheel discs & it was fine. You could get some short lengths of prefabbed 3/16" brake lines & some double female 3/8-24 connectors at your parts house & bypass it & see how it acts. Not exactly the same but I added '76 A (2.75 bore) discs to the front of my 65 dart & kept the OE splitter & no added prop valve and a dual bowl 1&1/8" alum MC & it worked flawless. It would lockup the rears (10x2 or 2&1/4 (whatever the BBP 7&1/4 is) with hard brakeing but no issue. Ceramic pads in the front. No pad wear that I ever noticed. EDIT the connectors are double female IFF inverted flare female (will have a recessed conical seat on each side of the brass connector)
